Greetings,
I still haven't figured out the answer to this one.
I'm using Grass-GIS 6.3 cvs - most things working okay.
To try and get Ghostscript I have installed Gutenprint. However, all the Ghostscript-dependent modules in Grass-GIS still respond "Ghostscript not found". So either I need to set a path statement somewhere, or I need to move the Ghostscript libraries to where Grass-GIS can find them. How do I do this?
Richard Chirgwin
I don't think Gutenprint comes with the gs executable. I think it had gs once long ago before it's name was changed to gutenprint. And then I believe you still had to install one of the ghostscript binary packages. I haven't seen any new ghostscript binary packages for OSX.
I think your stuck with building ghostscript yourself. Can't help you with that.
But the GUI (gis.m) should not need ghostscript, but use lpr instead for printing. d.m probably still has a dependence of gs for printing, but you should really not be using d.m.
On Dec 15, 2007, at 7:37 PM, Richard Chirgwin wrote:
Greetings,
Richard Chirgwin
grass-user mailing list
grass-user@lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
