[GRASS-user] gis.m crashes at startup
On Oct 7, 2009, at 9:00 AM, grass-user-request@lists.osgeo.org wrote:
Date: Wed, 7 Oct 2009 16:56:17 +0200
Subject: [GRASS-user] gis.m crashes at startup
To: grass-user@lists.osgeo.org
Message-ID:
  <730a39860910070756p20c2685ayaeb89d47f4a37372@mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
Hi List!
I've a problem running grass 6.5 svn on Ubuntu 8.04 64 bit (just installed).
When entering a location, gis.m crashes and in terminal it writes:
GRASS 6.5.svn (brenta):~ > Error in startup script: can't read "prj(proj)":
no such variable
   while executing
"if { $prj(proj) == "ll"} {set proj_is_ll 1}"
   (procedure "MapCanvas::get_mapunits" line 22)
   invoked from within
   (procedure "MapCanvas::create" line 37)
   invoked from within
"MapCanvas::create"
   (procedure "Gm::startmon" line 11)
   invoked from within
"Gm::startmon"
   (procedure "Gm::create" line 79)
   invoked from within
"Gm::create"
   (procedure "main" line 30)
   invoked from within
"main $argc $argv"
   (file "/usr/local/grass-6.5.svn/etc/gm/gm.tcl" line 602)
Any idea?
You probably have a problem with your installation of gdal. In the terminal, try g.region -gp. This probably won't work, indicating a gdal (or possible PROJ) problem.
Michael
