Just updated from CVS, and get GUI errors:
Error in startup script: syntax error in expression
"int(abs(7:56:32.529906S - 8:12:51.471615S)/0:00:03.002889)": missing
close parenthesis at end of function call
while executing
"expr int(abs([lindex $region 0] - [lindex $region 1])/[lindex $region 4])"
(procedure "MapCanvas::currentzoom" line 31)
invoked from within
"MapCanvas::currentzoom $mon"
(procedure "MapCanvas::coordconv" line 24)
invoked from within
"MapCanvas::coordconv $mon"
(procedure "MapCanvas::create" line 72)
invoked from within
"MapCanvas::create"
(procedure "Gm::startmon" line 11)
invoked from within
"Gm::startmon"
(procedure "Gm::create" line 74)
invoked from within
"Gm::create"
(procedure "main" line 30)
invoked from within
"main $argc $argv"
(file "/usr/local/grass-6.3.cvs/etc/gm/gm.tcl" line 528)
thanks
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Confirmed.
It happens in LatLong locations since the numbers are treated
as DMS and not decimal degrees.
Michael, could you take a look?
It would be nice to have it fixed before the next snapshot
is generated (in 7 hours from now). Otherwise I'll trigger
a new one once fixed.
while executing
invoked from within
invoked from within
invoked from within
"MapCanvas::create"
invoked from within
"Gm::startmon"
invoked from within
"Gm::create"
invoked from within
"main $argc $argv"
thanks
_________________
grassuser mailing list
grassuser@grass.itc.it
followup: a fix was posted to CVS on Sunday and the snapshots regenerated.
Markus Neteler wrote on 08/25/2006 10:19 PM:
Confirmed.
while executing
invoked from within
invoked from within
invoked from within
"MapCanvas::create"
invoked from within
"Gm::startmon"
invoked from within
"Gm::create"
invoked from within
"main $argc $argv"
thanks
_________________
