I have done a cvs update of grass 63 a couple of times over the past couple of days and still have the problem that the gis.m windows appear briefly and then disappear.
The terminal window reports
WARNING: This feature is superseded and will be removed in future versions of GRASS. Use the -g flag in combination with other print flats, e.g. -pg.
This behavior happens whether I start with the gui or use the text flag and then run gis.m.
Any suggestions on how to diagnose or fix greatly appreciated.
Jerry
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
Which operating system are you using? I see a simmilar behaviour on Ubuntu 6.06.1 while it seems to be gone on 6.10
Mit freundlichen Grüßen / With kindest regards
Stefan Paulick
http://www.urbeli.com
mailto://stefan.paulick@urbeli.com
Can confirm the same problem with ActiveState Tcl/Tk 8.4.13 on Windows. The splash screen and the output gronsole.tcl window appear and then disappear. No other gis.m Windows appear.
Actually now that I think about it the same or similar behaviour was apparent before Christmas with the Tcl/Tk 8.4.1 version that can be downloaded from the MinGW/Msys site (I can't remember exactly where), but at that stage it still worked OK with 8.4.13. But now that doesn't work. I didn't report it before Christmas as I thought it might be a problem with my set-up. Perhaps some incompatiblity has been introduced somewhere. But it seems so hard to diagnose errors with Tcl!
Paul
Jerry
Gerald Nelson
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
grassuser mailing list
grassuser@grass.itc.it
Just to confirm what Maciek said, my comment about the Tcl versions was a red herring. Using the December 20th version of g.region (and all other CVS copy current) it now works fine with both Tcl versions. My problem with the 8.4.1 installation was due to a local modification I'd made to g.region in connection with an unrelated problem (unable to read WIND file with Windows-style line endings).
Paul
