[GRASS-user] .gislock
A GRASS data set was sent to me - however, I am unable to open any of the mapsets in either grass6.4 or grass7 due to the following error message:
Starting GRASS …
/GRASSsf/PERMANENT/.gislock: Permission denied
ERROR: /Applications/GRASS-6.4.app/Contents/MacOS/etc/lock: Unable to properly access /GRASSsf/PERMANENT/.gislock
I also tried to create a new mapset in the GRASSsf dataset but get this error:
Unable to create new mapset: [Errro 13] Permission denied
I tried changing permissions on .gislock, i.e.
-rwxrwxrwx+ 1 jchoate staff 4 Nov 15 2013 .gislock
however - I still can not open anything.
Can anyone advise how to fix this so I can access this dataset/mapsets?
thank you,
Janet
Tague Team Lab Manager
1005 Bren Hall
UCSB, Santa Barbara, CA.
On Sun, 26 Jul 2020, Janet Choate wrote:
Starting GRASS ...
Janet,
Did you try removing it (or, at least, renaming it to another, inocuous
name?)
Rich
pirmd., 2020. g. 27. jūl., plkst. 05:52 — lietotājs Janet Choate
(<jsc.eco@gmail.com>) rakstīja:
Check permissions of folder containing .gislock file. Are you the
owner of that folder? Does it have rwx for your user?
If it doesn't help, please provide tested GRASS 7 version and install
method (self compiled, packages, ...).
Good luck,
Māris.
