[GRASS-user] gparser example for v.to.rast
Hello,
Is there a command to get the gparser code for a certain module from
the GRASS command line? like v.to.rast --gparser.
This is interesting to me as I 'd like to know how get certain parts
of the interactive form also implemented in my own python module.
cheers,
/johannes
NEU: FreePhone 3-fach-Flat mit kostenlosem Smartphone!
Jetzt informieren: http://www.gmx.net/de/go/freephone/
certain module from the GRASS command line? like
yes,
v.to.rast --script
for python make the first line
#!/usr/bin/env python
instead of
#!/bin/sh
and replace the bits after the end of the #% lines
with something like,
import grass.script as grass
def main():
    ...code goes here
    ...end of your code
if __name__ == "__main__":
    options, flags = grass.parser()
    atexit.register(cleanup)
    main()
explore the python scripts in grass7/scripts/ for
examples.
Hamish
Hi Hamish,
thank you…
–script
this was the hint I was looking for… I just couldn’t remember.
/johannes
