It’s been a while since I’ve tried doing this, so I’m not familiar with the state of the wxgui, but is it possible to do a graphical selection in the wx monitor? I see a tool that says ‘Select vector features’, but as far as I can tell you can only select one vector object at a time. I have to select a few hundred polygons, and it is not possible to select them from attributes or category numbers.
The ideal solution would be to draw a rectangle on the monitor, and have that tool append to the selection; then pan and zoom, and repeat until selection is complete. Is this possible somehow?
~ Eric
Hi Eric,
Yes, you can only choose polygons one by one… however, keeping Ctrl pressed, you can select multiple (one by one) polygons and you get a dialog that accumulates them and provides the option to create a new map out of the selection.
hth,
Vero
El jue., 25 jul. 2019 a las 18:44, Eric Patton (<eric.r.patton@protonmail.com>) escribió:
~ Eric
grass-user mailing list
grass-user@lists.osgeo.org
