[GRASS-user] GRASS-6.2.3: Compilation problems with NVIZ
Hi everyone,
I tryed to compile GRASS-6.2.3 sources on my machine with ubuntu 7.10.
configure step went well but I had an error during MAKE.
the message error told to CD on “/visualization/nviz” and then type MAKE.
Now the message errors are:
make[1]: Entering directory /home/roberto/grass-6.2.3/visualization/nviz/src' gcc -I/home/roberto/grass-6.2.3/dist./include -g -O2 -I/home/roberto/grass-6.2.3/dist./include -I/usr/include -DPACKAGE=\""grassmods"\" -I/home/roberto/grass-6.2.3/dist./include \ -o OBJ./nvizAppInit.o -c nvizAppInit.c In file included from togl.h:16, from nvizAppInit.c:8: togl_ws.h:4:26: error: grass/config.h: Nessun file o directory togl_ws.h:14:3: error: #error None of OPENGL_X11, OPENGL_AQUA or OPENGL_WINDOWS defined In file included from nvizAppInit.c:8: togl.h:53:23: error: GL/gl.h: Nessun file o directory In file included from nvizAppInit.c:8: togl.h:165: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘Togl_LoadBitmapFont’ togl.h:166: error: expected declaration specifiers or ‘...’ before ‘GLuint’ togl.h:215: error: expected ‘)’ before ‘left’ In file included from nvizAppInit.c:9: interface.h:21:23: error: grass/gis.h: Nessun file o directory interface.h:22:25: error: grass/gsurf.h: Nessun file o directory interface.h:23:27: error: grass/gstypes.h: Nessun file o directory In file included from nvizAppInit.c:9: interface.h:67: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘FontBase’ interface.h:86: error: ‘MAX_CPLANES’ undeclared here (not in a function) interface.h:90: error: ‘MAX_LIGHTS’ undeclared here (not in a function) interface.h:280: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘load_font’ interface.h:363: error: expected ‘)’ before ‘*’ token interface.h:364: error: expected ‘)’ before ‘*’ token interface.h:365: error: expected ‘)’ before ‘*’ token interface.h:366: error: expected ‘)’ before ‘*’ token interface.h:367: error: expected ‘)’ before ‘*’ token interface.h:368: error: expected ‘)’ before ‘*’ token interface.h:369: error: expected declaration specifiers or ‘...’ before ‘geosite’ interface.h:370: error: expected declaration specifiers or ‘...’ before ‘geosite’ interface.h:371: error: expected declaration specifiers or ‘...’ before ‘geosite’ interface.h:372: error: expected ‘)’ before ‘*’ token interface.h:373: error: expected ‘)’ before ‘*’ token interface.h:374: error: expected ‘)’ before ‘*’ token interface.h:375: error: expected ‘)’ before ‘*’ token interface.h:376: error: expected ‘)’ before ‘*’ token make[1]: *** [OBJ./nvizAppInit.o] Error 1 make[1]: Leaving directory /home/roberto/grass-6.2.3/visualization/nviz/src’
make: *** [nvwish] Error 2
Any suggestion to fix the problem?
Thank you,
Roberto
Inviato da Yahoo! Mail.
La web mail più usata al mondo.
Roberto.
it doesn't find GL/gl.h and others which means that you didn't yet install
the development package for OpenGL.
On Tue, Mar 11, 2008 at 5:50 PM, roberto caselli
<roberto.caselli@yahoo.it> wrote:
Hi everyone,
the message error told to CD on "/visualization/nviz" and then type MAKE.
`/home/roberto/grass-6.2.3/visualization/nviz/src'
togl.h:165: error: expected '=', ',', ';', 'asm' or '__attribute__' before
'Togl_LoadBitmapFont'
togl.h:166: error: expected declaration specifiers or '...' before 'GLuint'
togl.h:215: error: expected ')' before 'left'
interface.h:67: error: expected '=', ',', ';', 'asm' or '__attribute__'
before 'FontBase'
interface.h:86: error: 'MAX_CPLANES' undeclared here (not in a function)
interface.h:90: error: 'MAX_LIGHTS' undeclared here (not in a function)
interface.h:280: error: expected '=', ',', ';', 'asm' or '__attribute__'
before 'load_font'
interface.h:363: error: expected ')' before '*' token
interface.h:364: error: expected ')' before '*' token
interface.h:365: error: expected ')' before '*' token
interface.h:366: error: expected ')' before '*' token
interface.h:367: error: expected ')' before '*' token
interface.h:368: error: expected ')' before '*' token
interface.h:369: error: expected declaration specifiers or '...' before
'geosite'
interface.h:370: error: expected declaration specifiers or '...' before
'geosite'
interface.h:371: error: expected declaration specifiers or '...' before
'geosite'
interface.h:372: error: expected ')' before '*' token
interface.h:373: error: expected ')' before '*' token
interface.h:374: error: expected ')' before '*' token
interface.h:375: error: expected ')' before '*' token
interface.h:376: error: expected ')' before '*' token
Thank you,
Roberto
grass-user mailing list
grass-user@lists.osgeo.org
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
On Tue, 2008-03-11 at 22:09 +0100, Markus Neteler wrote:
Roberto.
Also,
if you still have trouble after installing OpenGL stuff maybe you need
to do following:
(locate where the glx.h file is... probably under /usr/include/GL)
cd /usr/include/GL
sudo ln glxATI.h glx.h
Nikos
7.10. configure step went well but I had an error during MAKE.
MAKE.
that doesn't look very healthy.
Hamish
      ____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
