[GRASS-user] Grass 6.2 crashes fedora 6
I am running fedora core 6 and am having some difficulties running
grass 6.2. I am able to create a location and mapset using EPSG
codes, however as soon as I "Enter Grass" the application crashes.
Any ideas or workarounds.
Travis K.
Toronto, Canada
"She knows there's no success like failure
And that failure's no success at all."
-Bob Dylan-
Travis,
could you define "crashes"?
BTW: 5 minutes ago I have packaged GRASS 6.2.2RC1 which probably
cures potential gis.m problems (I suspect that you refer to this).
Travis Kirstine wrote:
Travis K.
Toronto, Canada
-Bob Dylan-
View this message in context: http://www.nabble.com/Grass-6.2-crashes-fedora-6-tf3828599.html#a10860962
Manuel,
I am running:
Linux version 2.6.20-1.2948.fc6
Markus,
I believe this is the problem you are referring to, the gis.m will
start for a few seconds then disappears after "entering grass". I
will give 6.2.2 a try.
Thanks
Travis
On 29/05/07, Markus Neteler <neteler@itc.it> wrote:
Travis,
> Hi all,
> Travis K.
> Toronto, Canada
> -Bob Dylan-
grassuser mailing list
grassuser@grass.itc.it
Travis K.
Toronto, Canada
-Bob Dylan-
Sorry to bother you again, I tried the grass6.2.2 cvs update but am
still having the same issues (see below). I thought it could be a
permission issue but changing the permission didn't fix the problem.
Any thoughts.
Travis
Starting GRASS ...
/usr/local/grass6.2.2cvs-x86_64-unknown-linux-gnu-26_05_2007/etc/Init.sh:
line 319: /usr/local/grass6.2.2cvs-x86_64-unknown-linux-gnu-26_05_2007/etc/clean_temp:
cannot execute binary file
line 567: /usr/local/grass6.2.2cvs-x86_64-unknown-linux-gnu-26_05_2007/bin/g.gisenv:
line 568: /usr/local/grass6.2.2cvs-x86_64-unknown-linux-gnu-26_05_2007/bin/g.gisenv:
line 569: /usr/local/grass6.2.2cvs-x86_64-unknown-linux-gnu-26_05_2007/bin/g.gisenv:
line 575: /usr/local/grass6.2.2cvs-x86_64-unknown-linux-gnu-26_05_2007/etc/lock:
Unable to properly access ///.gislock
Please notify system personel.
On 29/05/07, Travis Kirstine <traviskirstine@gmail.com> wrote:
Manuel,
I am running:
Markus,
Thanks
Travis
> Travis,
> Markus
> > Hi all,
> > Travis K.
> > Toronto, Canada
> > -Bob Dylan-
Travis K.
Toronto, Canada
-Bob Dylan-
Travis K.
Toronto, Canada
-Bob Dylan-
Any thoughts.
Travis
Starting GRASS ...
line 319:
what does
file /usr/local/grass6.2.2cvs-x86_64-unknown-linux-gnu-26_05_2007/etc/clean_temp
and
file /usr/local/grass6.2.2cvs-x86_64-unknown-linux-gnu-26_05_2007/bin/g.gisenv
say?
> Manuel,
> I am running:
