[GRASS-user] grass 6.2 crashes when creating location
I just installed grass 6.2 using the max rpms:
yum -y localinstall gdal-1.3.2-max.1.fc6.i386.rpm
gdal-devel-1.3.2-max.1.fc6.i386.rpm
gdal-grass-1.3.2-1.fdr.fc6.i386.rpm geos-2.2.3-1.fc6.i386.rpm
geos-devel-2.2.3-1.fc6.i386.rpm geos-doc-2.2.3-1.fc6.i386.rpm
grass-6.2.1-1.fdr.fc6.i386.rpm jasper-1.701.0.uuid-1.i386.rpm
jasper-devel-1.701.0.uuid-1.i386.rpm
Grass starts fine but crashes when creating a location based on
Projection Values. Also, the EPSG codes are not available to create a
location base on EPSG codes.
I did have some issues installing the geos rpm (geos not signed error)
but I just edited the yum.config file: gpgcheck=0
Do in need the proj rpm from the min rpms as well
Any Ideas?
Travis K.
Toronto, Canada
"She knows there's no success like failure
And that failure's no success at all."
-Bob Dylan-
It's fixed in CVS for 6.3. No ideas if it's backported to 6.2 (IIRC no).
Workaround - download Spearfish dataset, open it, close it and then try again.
Maris.
2007/5/24, Travis Kirstine <traviskirstine@gmail.com>:
Any Ideas?
Travis K.
Toronto, Canada
-Bob Dylan-
grassuser mailing list
grassuser@grass.itc.it
Maris,
I gave your workaround a try but Grass crash right after I "Enter
Grass". Is it possible to create a fresh install. I attempted yum
remove ....rpm but with no luck
Maris.
> Any Ideas?
> Travis K.
> Toronto, Canada
> -Bob Dylan-
Travis K.
Toronto, Canada
-Bob Dylan-
