[GRASS-user] GRASS 6.3.0RC5
GRASS 6.3.0RC5 loaded well on Win-XP p-III 256mb RAM machine.
A long awaited release. Congrats.
Ravi Kumar
BUG:
using spearfish57 roads data for Net work analysis
‘display shortest path’
gives the following error.
can’t read “xmonlist”: no such variable
while executing
“lindex $xmonlist 0”
(procedure “guarantee_xmon” line 17)
invoked from within
“guarantee_xmon”
(menu invoke)
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
On Fri, Mar 21, 2008 at 4:11 PM, RAVI KUMAR <ravivundavalli@yahoo.com> wrote:
BUG:
native winGRASS does not have support for X11, I assume
that you tried d.path which isn't supported AFAIK.
See
http://grass.gdf-hannover.de/wiki/WinGRASS_Current_Status#Won.27t_fix_.28at_least_not_immediately.29
RAVI KUMAR wrote:
> BUG:
FWIW d.path has the coor= parameter which lets it run non-interactively.
No idea if that means it will compile, but I would guess stuff could be
#ifdef'd into allowing it to run.
or maybe it is this part: "The user needs to display a vector map before
using d.path." But if map= was given it shouldn't need to worry about the
Xmon at all?
Hamish
      ____________________________________________________________________________________
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
