[GRASS-user] grass 6.3cvs stability
hello there,
i just installed Grass 6.3CVS..this is my first time
to use it after several attempts of installing it..my
promotor would like us to use this software here in
europe rather than using the expensive commercial
software..since it is under development, may i know if
its possible to import/open ESRI shapefiles? I DONT
KNOW HOW TO DO IT, i dont have any knowledge in
language programming or any other computer courses as
well, im just a student with other technical field of
specialization..Any help would be greatly appreciated.
Thanks a lot.
Precila
____________________________________________________________________________________
Do you Yahoo!?
Everyone is raving about the all-new Yahoo! Mail beta.
http://new.mail.yahoo.com
It's easy to import ESRI shapefiles. Just do file/import/Vector map/Multiple
formats using GDAL and follow the directions. But...
Grass is much more finicky about explicitly specifying locations and
resolutions than ArcGis so it really helps to read the tutorial material on
how Grass works with regions and mapsets.
And one other thing about shapefiles. It is possible to specify a shapefile
that doesn't include projection information. Grass imports it as an xy
projection (ie no projection). So make sure your shapefile has a .prj file
associated with it.
Regards, Jerry
-----Original Message-----
From: grassuser-bounces@grass.itc.it [mailto:grassuser-bounces@grass.itc.it]
On Behalf Of Precila Salcedo
Sent: Wednesday, December 06, 2006 8:21 AM
To: grassuser@grass.itc.it
Subject: [GRASS-user] grass 6.3cvs stability
hello there,
Thanks a lot.
Precila
________
Do you Yahoo!?
grassuser mailing list
Hi Precila,
GRASS can import shape files or open it.
just use the gis manager or the command line option
v.in.ogr dsn=yourshapefile.shp output=yourvectorfile
or take a closer look at
http://grass.itc.it/grass63/manuals/html63_user/v.in.ogr.html
Malte
Precila Salcedo schrieb:
hello there,
Thanks a lot.
Precila
Do you Yahoo!?
Hi Malte,
thanks a lot, i tried doing several things but failed
to get result.. these the things i did that got not
result.. what seems to be the problem with these? i
need to import shapefiles and work with my files
ASAP..Thanks...
i was importing vector files by:
file/import/vector map/various formats using OGR...
(other choices were ASCII points file or GRASS ASCII
vector file, Input old GRASS vector format, dxf file,
ESERI e00 format, Garmin GPS Waypoints/Routes/Tracks,
GEO net Name server country files (US-NGA GNS), Matlab
& MapGen files)
here's what i did:
v.in.ogr -l dsn=C:/ESRI/ESRIDATA/WORLD/CITIES.SHP
output=cities.grc min_area=0.0001 snap=-1
Data source contains 1 layers:
CITIES
v.in.ogr -l -f -c -z -t -o -e
dsn=E:/paj/flora_diversity.shp
output=c:/GIS/PGS/DATABASE/Flora_tst.shp
Available OGR Drivers:
  ESRI Shapefile
  MapInfo File
  UK .NTF
  SDTS
  TIGER
  S57
  DGN
  VRT
  AVCBin
  REC
  Memory
  CSV
  GML
  SQLite
  PostgreSQL
  ESRI Shapefile
  MapInfo File
  UK .NTF
  SDTS
  TIGER
  S57
  DGN
  VRT
  AVCBin
  REC
  Memory
  CSV
  GML
  SQLite
  PostgreSQL
v.in.ogr -l -f -z -e
dsn=C:/ESRI/ESRIDATA/EUROPE/country.shp
output=cntrygraz.ogr {layer=ESRI
Shapefile:country.shp} type=boundary snap=-1
location=C:/GIS/PGS
  ESRI Shapefile
  MapInfo File
  UK .NTF
  SDTS
  TIGER
  S57
  DGN
  VRT
  AVCBin
  REC
  Memory
  CSV
  GML
  SQLite
  PostgreSQL
v.in.ogr -l dsn=C:/ESRI/ESRIDATA/europe.apr
output=citiesgraz {layer=ESRI Shapefile:cities.shp}
snap=-1
--- Malte Halbey-Martin <malte@perlomat.de> wrote:
Hi Precila,
Malte
> hello there,
time
it..my
in
know if
DONT
as
of
appreciated.
> Thanks a lot.
> Precila
> Do you Yahoo!?
beta.
Want to start your own business?
Learn how on Yahoo! Small Business.
http://smallbusiness.yahoo.com/r-index
here's what i did:
v.in.ogr -l dsn=C:/ESRI/ESRIDATA/WORLD/CITIES.SHP output=cities.grc min_area=0.0001 snap=-1
CITIES
Hi Precila,
from the help page:
Flags:
  -l List available layers in data source and exit
so when you used the list flag it exited before importing anything.
try this:
v.in.ogr dsn=C:/ESRI/ESRIDATA/WORLD/CITIES.SHP output=cities.grc
   which is the same as this:
v.in.ogr dsn=C:/ESRI/ESRIDATA/WORLD/ layer=CITIES output=cities.grc
Hamish
Hi
as far as I see, you used the -l switch which causes v.in.ogr to list all available layer and exit without importing the shape file. Just turn out that switch
(on the command line:
v.in.ogr dsn=C:/ESRI/ESRIDATA/WORLD/CITIES.SHP output=cities.grc min_area=0.0001 snap=-1
or disable the button in the gis manager)
and than it must work. normally a status of the import is displayed. You can check if the import worked on the command line with:
g.list vect
Hi Malte,
ASAP..Thanks...
& MapGen files)
here's what i did:
CITIES
  ESRI Shapefile
  MapInfo File
  UK .NTF
  SDTS
  TIGER
  S57
  DGN
  VRT
  AVCBin
  REC
  Memory
  CSV
  GML
  SQLite
  PostgreSQL
  ESRI Shapefile
  MapInfo File
  UK .NTF
  SDTS
  TIGER
  S57
  DGN
  VRT
  AVCBin
  REC
  Memory
  CSV
  GML
  SQLite
  PostgreSQL
location=C:/GIS/PGS
  ESRI Shapefile
  MapInfo File
  UK .NTF
  SDTS
  TIGER
  S57
  DGN
  VRT
  AVCBin
  REC
  Memory
  CSV
  GML
  SQLite
  PostgreSQL
snap=-1
Hi Precila,
Malte
hello there,
time
it..my
in
know if
DONT
as
of
appreciated.
Thanks a lot.
Precila
Do you Yahoo!?
beta.
failed
> here's what i did:
> CITIES
Hi Precila,
from the help page:
Flags:
importing anything.
try this:
output=cities.grc
output=cities.grc
Hamish
Hi Hamish,
i tried your suggestion by opening grass and typing
the command straight on the Output GIS.m panel (lower
half of the panel) then RUN it;
output=cities.grc
how will i open it now?..i was looking for the file
cities.grc but cant find it, was it automatically
saved on my default location or somewhere else? my
default dataset is Spearfish60 PERMANENT. wil i open
it using file/workspace/open or using
file/import/vector map??? ..im having difficulty with
this. thanks a lot.
Precy
Any questions? Get answers on any topic at www.Answers.yahoo.com. Try it now.
Hello Precila,
when you run
g.list vect
on the command line all available vector files are listed in the location you are working. Does your imported cities.grc appear?
Malte
failed
here's what i did:
CITIES
Hi Precila,
from the help page:
Flags:
importing anything.
try this:
output=cities.grc
output=cities.grc
Hamish
Hi Hamish,
output=cities.grc
this. thanks a lot.
Precy
