[GRASS-user] GRASS 6.4.0 Windows, problem with digitizing tool
Dominik wrote:
Just typed in the command, just as shown in your example, but still the
result remains the same: I can start to create vectors (point, line an
polygon) but the raster file (an imported ERDAS Imagine 9.2 file) which
shall serve as a source is not being loaded into the digitizing window!
perhaps the computational region settings do not match the map?
try "g.region rast=your_background_map" before running v.digit.
Hamish
Hi Hamish,
I tried it and it finally worked! You really helped me to get out of
trouble!
Thank you very much,
Dominik
View this message in context: http://n2.nabble.com/GRASS-6.4.0-Windows%2C-problem-with-digitizing-tool-tp3196193p3202150.html
