[GRASS-user] GRASS 6.4.1RC1 wxPython problems on Solaris
Today I compiled GRASS 6.4.1RC1 on Solaris 10 (SPARC) and encountered some problems with the wxPython-based GUI. When I try to open a preferences Dialog in Layer Manager, I get some error output (see further below) and nothing happens. This error also existed in version 6.4.0 and seems to be related to the following posts:
http://trac.osgeo.org/grass/ticket/882
http://lists.osgeo.org/pipermail/grass-user/2011-February/059569.html
My desktop is configured for a German locale and UTF-8. However, when entering "r.cost --interface-description", I get "<?xml version="1.0" encoding="646"?>" - so this might be something specific to Solaris.
I hope you can help me with this.
Ulli Wölfel
here comes the error output:
   File "/opt/local/grass-6.4.1RC1/etc/wxpython/gui_modules/l
ayertree.py", line 587, in OnPopupProperties
self.PropertiesDialog(self.layer_selected)
ayertree.py", line 904, in PropertiesDialog
parentframe=self)
   File "/opt/local/grass-6.4.1RC1/etc/wxpython/gui_modules/m
enuform.py", line 2051, in ParseCommand
self.grass_task = self.ParseInterface(cmd)
enuform.py", line 2022, in ParseInterface
tree = etree.fromstring(getInterfaceDescription(cmd[0]))
   File "/usr/local/lib/python2.6/xml/etree/ElementTree.py",
line 963, in XML
parser.feed(text)
line 1245, in feed
self._parser.Parse(data, 0)
xml.parsers.expat
ExpatError
XML declaration not well-formed: line 1, column 30
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
On Tue, Feb 22, 2011 at 3:30 PM, Ulli Wölfel <uwoelfel@gmx.de> wrote:
I have searched and found
http://gcc.gnu.org/ml/java/2001-05/msg00111.html
"It's the default encoding for the "C" locale."
Found also something about "charset.alias"
http://www.stata.com/support/faqs/unix/charset.html
I wonder if you have any charset.alias file on your Solaris system which
could be tuned.
The encoding is obtained from nl_langinfo(CODESET). In this case,
"646" is probably used as a shorthand for ISO-646, which specifies
ASCII as well as national variants. I suspect that Python doesn't
accept "646" as a valid encoding.
Was GRASS configured with the --with-nls switch? If not, it will
operate in the "C" locale, which uses ASCII.
Am 10.03.2011 um 16:03 schrieb Glynn Clements:
Thanks a lot! That was my mistake - I now recompiled it with --with-nls and it works fine.
Btw. in order to get it to compile, I had to edit include/Make/Platform.make and set INTLLIB = -lintl
Maybe this should be fixed in the configure script.
Ulli Wölfel
The configure script sets INTLLIB according to the location of the
gettext() function. If gettext() is available in the standard C lib,
INTLLIB will be empty, otherwise -lintl is tried.
What error were you getting before you changed INTLLIB? If GRASS needs
libintl for a function other than gettext(), we need to know which
one.
Am 11.03.2011 um 18:30 schrieb Glynn Clements:
one.
It was a linking error. The undefined symbols were:
libintl_bindtextdomain
libintl_dgettext
> one.
libintl_dgettext
Ugh. My guess is that both libc and libintl have the relevant
functions, but libintl.h provides macros which redirect to the
libintl_* versions. So configure detects that libintl isn't needed,
but the inclusion of <libintl.h> by glocale.h changes that.
Can you test the attached patch (after patching configure.in, the
configure script needs to be re-built with autoconf 2.13)?
(attachments)
libintl.patch (649 Bytes)
