[GRASS-user] GRASS 6.4.2 RC3 will not load on Windows 7
Dear all
GRASS 6.4.2 RC3, downloaded from OSGEO4W, does not load on Windows 7. When I double click on the icon, a black window opens and closes immediatly afterwards.
Best regards
F.
there seems to be a path qoting issue in the start-bat-File.
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-6-4-2-RC3-will-not-load-on-Windows-7-tp7183539p7183853.html
can you change manually (wit a texteditor) the file
C:\OSGeo4W\bin\grass64.bat and give us a feedback?
the last line from
   "%GISBASE%"\etc\init.bat %*
into
   "%GISBASE%\etc\init.bat" %*
or
   %GISBASE%\etc\init.bat %*
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-6-4-2-RC3-will-not-load-on-Windows-7-tp7183539p7184010.html
No, it still doesn´t work. Tried both options.
the last line from
“%GISBASE%”\etc\init.bat %*
into
“%GISBASE%\etc\init.bat” %*
or
Helmut
grass-user mailing list
grass-user@lists.osgeo.org
The launcher of GRASS 6.5svn/osgeo4w still broken too.
-- Giovanni --
wrote:
        >>GRASS 6.4.2 RC3, downloaded from OSGEO4W, does not load on
        Windows 7.
        >there seems to be a path qoting issue in the start-bat-File.
        the last line from
        into
        or
        Helmut
        Nabble.com.
very strange.
because here, on a WinVista32-box, osgeo4w-GRASS 6.4.2 RC3 is starting also
with the path-issue, but with some error messages:
C:\>call C:\OSGeo4W\apps\grass\grass-6.4.2RC3\etc\env.bat
C:\>set GISBASE=C:\OSGeo4W\apps\grass\grass-6.4.2RC3
C:\>set GRASS_SH=C:\OSGeo4W\apps\msys\bin\sh.exe
C:\>set GRASS_WISH=C:\OSGeo4W\bin\wish.exe
C:\>set GRASS_PYTHON=C:\OSGeo4W\bin\python.exe
C:\>set GRASS_PROJSHARE=C:\OSGeo4W\share\proj
C:\>set GRASS_HTML_BROWSER=explorer
C:\>set
PATH=C:\OSGeo4W\apps\grass\grass-6.4.2RC3\bin;C:\OSGeo4W\apps\grass\grass-6.4.2RC3\lib;C:\OSGeo4W\bin;C:\windows\system32;[...]
C:\>"C:\OSGeo4W\apps\grass\grass-6.4.2RC3"\etc\init.bat -wx
Das System kann den angegebenen Pfad nicht finden.
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-6-4-2-RC3-will-not-load-on-Windows-7-tp7183539p7184114.html
tested here on my WinVista32-box, although the path-issue GRASS
6.5svn/osgeo4w is also starting:
C:\>call C:\OSGeo4W\apps\grass\grass-6.5.svn\etc\env.bat
C:\>set GISBASE=C:\OSGeo4W\apps\grass\grass-6.5.svn
C:\>set
PATH=C:\OSGeo4W\apps\grass\grass-6.5.svn\bin;C:\OSGeo4W\apps\grass\grass-6.5.svn\lib;C:\OSGeo4W\bin;[...]
C:\>"C:\OSGeo4W\apps\grass\grass-6.5.svn"\etc\init.bat -wx
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-6-4-2-RC3-will-not-load-on-Windows-7-tp7183539p7184153.html
Helmut wrote:
C:\>set
-wx
[The system cannot find the indicated path.]
do some paths exist in %PATH% which do not exist
in the file system? (e.g. for addons)
Hamish
hi
now I had the chance to test also on my Win7-64-bit-box:
I can confirm that here on my Win7-64-bit-box.
but it's strange, on my WinVista-32-bit-box it is - although the message:
The system cannot find the indicated path. - working.
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-6-4-2-RC3-will-not-load-on-Windows-7-tp7183539p7187213.html
Hi Hamish,
Helmut wrote:
C:\>set
-wx
what i have done on the windows-command-line:
C:\OSGeo4W\bin>grass64.bat > XXX.log
the content of XXX.log:
C:\OSGeo4W\bin>call C:\OSGeo4W\apps\grass\grass-6.4.2RC3\etc\env.bat
C:\OSGeo4W\bin>set GISBASE=C:\OSGeo4W\apps\grass\grass-6.4.2RC3
C:\OSGeo4W\bin>set GRASS_SH=C:\OSGeo4W\apps\msys\bin\sh.exe
C:\OSGeo4W\bin>set GRASS_WISH=C:\OSGeo4W\bin\wish.exe
C:\OSGeo4W\bin>set GRASS_PYTHON=C:\OSGeo4W\bin\python.exe
C:\OSGeo4W\bin>set GRASS_PROJSHARE=C:\OSGeo4W\share\proj
C:\OSGeo4W\bin>set GRASS_HTML_BROWSER=explorer
C:\OSGeo4W\bin>set
PATH=C:\OSGeo4W\apps\grass\grass-6.4.2RC3\bin;C:\OSGeo4W\apps\grass\grass-6.4.2RC3\lib;C:\OSGeo4W\bin;C:\Program
Files\Common Files\Microsoft Shared\Windows
Live;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\Program
Files (x86)\Common Files\Roxio Shared\DLLShared\;C:\Program
Files\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth
Software\syswow64;C:\Program Files (x86)\ATI
Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\Common Files\Roxio
Shared\OEM\DLLShared\;C:\Program Files (x86)\Common Files\Roxio
Shared\OEM\12.0\DLLShared\;C:\Program Files
(x86)\Roxio\OEM\AudioCore\;C:\Program Files\TortoiseSVN\bin;C:\Program Files
(x86)\Hewlett-Packard\HP ProtectTools Security Manager\Bin\;c:\Program Files
(x86)\Microsoft SQL Server\100\Tools\Binn\;c:\Program Files\Microsoft SQL
Server\100\DTS\Binn\;c:\Program Files (x86)\Microsoft SQL
Server\100\Tools\Binn\VSShell\Common7\IDE\;c:\Program Files (x86)\Microsoft
SQL Server\100\DTS\Binn\;c:\Program Files (x86)\Microsoft Visual Studio
9.0\Common7\IDE\PrivateAssemblies\;C:\Program Files
(x86)\Intel\Services\IPT\;C:\OSGeo4W\apps\msys\bin
C:\OSGeo4W\bin>C:\OSGeo4W\apps\grass\grass-6.4.2RC3\etc\init.bat
I can't find any obvious in the %PATH%
Helmut
p.s. keep in mind, osgeo4w-GRASS 6.4.2 RC3 is starting in my
WinVista-32bit-box, but not in my Win7-64bit-box
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-6-4-2-RC3-will-not-load-on-Windows-7-tp7183539p7187230.html
you are right. I've found it.
see
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/lib/init/init.bat#L29
%WINGISBASE% for wingrass was recently changed to %GISBASE%, but it wasn't
changed in
if I change this manually in
C:\OSGeo4W\apps\grass\grass-6.4.2RC3\etc\Init.bat
then osgeo4w-GRASS 6.4.2RC3 is starting again.
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-6-4-2-RC3-will-not-load-on-Windows-7-tp7183539p7187487.html
see
changed in
but I've seen that in the standalone wingrass-installer %WINGISBASE% is
still defined:
C:\Program Files (x86)\GRASS 6.4\etc\env.bat
line 1: set WINGISBASE=%GISBASE%
there seems to be some inconsistency between the wingrass-standalone
installer and osgeo4w-wingrass.
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-6-4-2-RC3-will-not-load-on-Windows-7-tp7183539p7187544.html
-- Giovanni --
see http://lists.osgeo.org/pipermail/grass-commit/2012-January/021112.html
set WINGISBASE=%GISBASE% for starting in osgeo4w
please test the next update of GRASS 6.5svn/osgeo4w tomorrow or so.
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-6-4-2-RC3-will-not-load-on-Windows-7-tp7183539p7187673.html
2012/1/14 Helmut Kudrnovsky <hellik@web.de>:
I think it's better to eliminate this variable rather then introduce
it again. Why WINGISBASE is needed, it's just copy of GISBASE right?
It would be better to fix scripts which uses this variable, no?
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Martin Landa wrote
2012/1/14 Helmut Kudrnovsky &lt;hellik@&gt;:
see
Martin
grass-user@.osgeo
Hi Martin,
it was quick look where the problem is to not start within osgeo4w.
+1 for elimination of the variable duplication.
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-6-4-2-RC3-will-not-load-on-Windows-7-tp7183539p7189628.html
2012/1/15 Helmut Kudrnovsky <hellik@web.de>:
after some investigation, it's seems to me that WINGISBASE has sense
in G6, see [1]. I am not sure about consequence when we eliminate this
variable (?)
Martin
[1] http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/lib/init/init.bat#L44
has sense in G6, see [1]. I am not sure about
consequence when we eliminate this variable (?)
may I suggest to leave the (redundant?) variable
in there for 6.4.2 and set a new task ticket to see
if it can be eliminated for 6.4.3?
Hamish
2012/1/15 Hamish <hamish_b@yahoo.com>:
agreed, I will eliminate WINGISBASE in devbr6 for testing.
Martin
2012/1/15 Hamish <[hidden email]>:
for testing I've changed all WINGISBASE to GISBASE in
all seems to work.
+1 change in devbr6 and later to 6.4.3?
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-6-4-2-RC3-will-not-load-on-Windows-7-tp7183539p7190841.html
I just updated my osgeo4w installation and none of the GRASS versions
are starting using the menu shortcuts, not even GRASS 7 that used to
work until a few days ago.
cheers
-- Giovanni --
