Hi
I just installed GRASS 6.4.3 from the central ubuntu repository and tried to launch grass and got this on the command line:
WELCOME TO GRASS Version 6.4.3 2013
Have at your side all available GRASS tutorials
When working on your location, the following materials
are extremely useful:
A topo map of your area
Current catalog of available computer maps
Check the GRASS webpages for feedback mailinglists and more:
http://www.grass-gis.org
http://grass.osgeo.org
Hit RETURN to continue
Following this link: http://gis.stackexchange.com/questions/72876/grass-algorithms-no-longer-run-in-qgis-sextante I typed
grass --wxpython
grass64 --wypython
but I still can’t get grass to launch without the welcome message on the command line
How can I change this?
Thanks
Best regards
F.
have you also installed the GRASS GUI?
You can install it with 'sudo apt-get install grass-gui
/Johannes
On Sat, Nov 9, 2013 at 8:51 PM, Filipe Dias <filipesdias@gmail.com > wrote:
Hi
grass --wxpython
grass64 --wypython
Thanks
Best regards
F.
grass-user mailing list
grass-user@lists.osgeo.org
Hi
I checked and grass-gui is installed.
On Sat, Nov 9, 2013 at 8:27 PM, Johannes Radinger <johannesradinger@gmail.com > wrote:
/Johannes
Hi
grass --wxpython
grass64 --wypython
Thanks
Best regards
F.
On 09/11/2013 21:43, Filipe Dias wrote:
Hi
johannesradinger@gmail.com> wrote:
/Johannes
On Sat, Nov 9, 2013 at 8:51 PM, Filipe Dias <filipesdias@gmail.com> wrote:
Hi
1) Have at your side all available GRASS tutorials
2) When working on your location, the following materials
- A topo map of your area
- Current catalog of available computer maps
3) Check the GRASS webpages for feedback mailinglists and more:
http://gis.stackexchange.com/questions/72876/grass-algorithms-no-longer-run-in-qgis-sextanteI typed
grass --wxpython
grass64 --wypython
but I still can't get grass to launch without the welcome message on the
command line
Thanks
Best regards
F.
you can tried to launch with tcl-tk?
something like grass64 -tcltk
Cordialement
Etienne DELAY(IDSkype : etienne.delay.tic)
PhD student on evolution of vineyard landscape
laboratoire GEOLAB UMR 6042 CNRS
Université de Limoges, FLSH
39E rue Camille Guérin 87036 Limoges
blog : http://elcep.legtux.org
Hi
When I run grass64 -tcltk I still get the “Welcome message”. After I press “enter” it loads the tcktk. The same happens with wxpytho interface.
On Sun, Nov 10, 2013 at 9:18 AM, Etienne DELAY <etienne.delay@etu.unilim.fr > wrote:
Hi
/Johannes
Hi
grass --wxpython
grass64 --wypython
command line
Thanks
Best regards
F.
Cordialement
So it works when you specifies the interface?
On 10/11/2013 12:39, Filipe Dias wrote:
Hi
When I run grass64 -tcltk I still get the "Welcome message". After I press
"enter" it loads the tcktk. The same happens with wxpytho interface.
Hi
/Johannes
wrote:
Hi
tried
grass --wxpython
grass64 --wypython
command line
Thanks
Best regards
F.
Cordialement
Cordialement
Yes. But I have to press “Enter” everytime I want to run Grass.
The main problem is that this behaviour interferes with QGIS/Processing (Sextante) and it doesnt allow me to run grass algorithms.
I had a similar problem with Ubuntu 12.04 but when I run grass --wxpython, GRASS started loading wxpython without requiring me to press “Enter” everytime.
On Sun, Nov 10, 2013 at 12:51 PM, Etienne DELAY <etienne.delay@etu.unilim.fr > wrote:
Hi
Hi
/Johannes
wrote:
Hi
tried
grass --wxpython
grass64 --wypython
command line
Thanks
Best regards
F.
Cordialement
Cordialement
The problem was GRASS was not creating the “.grassrc6” file on the Home folder. I copied it a version from another installation and now it works.
Hi
Hi
/Johannes
wrote:
Hi
tried
grass --wxpython
grass64 --wypython
command line
Thanks
Best regards
F.
Cordialement
Cordialement
Hamish
November 13, 2013, 9:32am
9
to press "Enter" everytime.
fyi you can change the default startup GUI method with the g.gui module.
but explicitly specifying -gui or -wxpython from the command line to
start should record the preference permanently in your ~/.grassrc6 file.
Hamish
