[GRASS-user] GRASS 6.4.3 - Technical questions on Landsat TM/ETM+/OLI and other
Hey!
I am re-sending this email, I think it got blocked because of attached images jpg examples, if you want to see it, I will send it personally.
This is my first post, unfortunate it’s not to help somebody but to ask for some help… I do have to say, GRASS seems to be great so far and I feel my problems are probably user related.
I am pre-processing Landsat data (at the moment only TM and ETM) to use for a classification later, doesn’t matter.
Since all the data I’m acquiring comes as L1T (204/032), then the pre-processing workflow was done as follows:
DN → TOA reflectance(&temperature) → Cloud detection and masking (if necessary) → Topographic correction using ASTERM 30m DEM.
All data projection is as delivered by USGS (I don’t remember if I reprojected the DEM but most probably I did).
Imagery dates - 204/32:
TM4 - 1989001 (January 1, 1989)
TM5 - 2007027 (January 27,2007)
ETM+ - 2003023 (January 23,2003)
All until here seems fine I guess, but I am having the following issues:
  • Band seems saturated or affected by some “multiplier”. Such as TM4 composites look “normal” or as expected but TM5 and ETM+ seem pinkish or saturated as if one of the bands is saturated.
  • Since TM4 looks the most “normal”, all the others seem affected by some kind of noise (white noise?). Should I apply a Low pass filter of some kind?
  • Both i.landsat.rgb (runs endlessly) and i.landsat.dehaze (says it can’t find the GUI, I’ve re-installed it without success)
If you need added information, please ask and I’ll send you the commands. Here are the ones which i have been using.
Added note: I’m using Windows 8! (don’t know how important that can be)
Calling the file
r.in.gdal input=C:\Invader_B\GRASS_Workfolder_01\01_LT5\LT52040322007027MPS00\LT52040322007027MPS00_B1.TIF output=RAW_2007027_LT5_B.1
(i used DOS2 in this latest attempt since both uncorrected and DOS1 yield similar problems)
i.landsat.toar sensor=tm5 method=dos2 --overwrite --verbose input_prefix=RAW_2007027_LT5_B. output_prefix=2007027_LT5_B. metfile=C:\Invader_B\GRASS_Workfolder_01\01_LT5\LT52040322007027MPS00\LT52040322007027MPS00_MTL.txt
i.landsat.acca --overwrite --verbose -5 input_prefix=2007027_LT5_B. output=2007027_CloudMask
(The mask is not used by me since i visually see there are no clouds [there is snow in Serra da Estrela, famous place here])
Getting the illumination raster
i.topo.corr -i --overwrite base=ASTER_30m zenith=63.09559142 azimuth=153.85758094 out=ASTER.illu.prj
i.topo.corr base=ASTER.illu.prj zenith=63.09559142 method=c-factor --verbose --overwrite input=2007027_LT5_B.1,2007027_LT5_B.2,2007027_LT5_B.3,2007027_LT5_B.4,2007027_LT5_B.5,2007027_LT5_B.6,2007027_LT5_B.7 out=npca_topo_CM
r.colors -e map=npca_topo_CM.2007027_LT5_B.1@01_LT5 color=grey
d.rgb to display the image in attachment.
Pop-up window box text for i.landsat.dehaze:
“unable to fetch interface description for command i.landsat.dehaze.bat”.
Details: (…) ./scripts/i.landsat.dehaze: no such file or directory
Nuno César de Sá
+351 91 961 90 37
