Dear All,
Grass 6.4 has completed a third automatic update this week! However it still fails when trying to run the wxpython GU1
Following the last upgrade this morning attempting to run the Wxpthyon GUI returns
File”/opt/grass/etc/wxpython/wxgui.py”, line 34, in from lmgr.frame import GMFrame
File “/opt/grass/etc/wxpython/lmgr/frame.py", line 46, in from lmgr.layertree import LayerTree, UNIcons
File “/opt/grass/etc/wxpython/lmgr/layertree.py", line 37, in from mapdisp.frame import MapFrame
File “opt/grass/etc/wxpython/mapdisp/frame.py”, line 52, in from wxplot.profile import ProfileFrame
File “opt/grass/etc/wxpython/wxplot/profile.py”, line 23, in import wx.lib.plot as plot
File ‘usr/lib/python2.7/site-packages/wx-2.8gtk2-unicode/wx/lib/plot.py” line 132 in raise ImportError, “Numeric, numarray or numPy not found. \n. + msg
ImportError: Numeric, numarray or NumPy not found.
This module requires the Numeric/numarray or NumPy module, which could not be imported. It probably is not installed(it’s not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries.
Doing a Find on python returns the following
/etc/apparmour.d/abstractions/python
/usr/share/doc/packages/python
/usr/share/gdb/python
/usr/share/bash-completion/completion/python
/usr/share/kde4/apps/kconversion/scripting_support/python
/usr/lib/gimp/2.0/python
/usr/lib/libreoffice/share/scripts/python
usr/lib/python
/usr/bin/python
/opt/grass/etc/python
Doing a find on NumPy
/usr/lib/python2.7/site-packages/numpy
/usr/lib/python2.7/site-packages/numpy/core/include/numpy
Can anyone help get GRASS back up and running?
Thanks
Tim Southern
17, Park Close,
Sonning Common,
Oxfordshire
RG4 9RY
On 14 Nov 2014, at 14:05, grass-user-request@lists.osgeo.org wrote:
Send grass-user mailing list submissions to
grass-user@lists.osgeo.orgTo subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
grass-user-request@lists.osgeo.orgYou can reach the person managing the list at
grass-user-owner@lists.osgeo.orgWhen replying, please edit your Subject line so it is more specific
than “Re: Contents of grass-user digest…”Today’s Topics:
- FW:11/14/2014 2:34:02 AM 4 (Rebecca Stedham)
- Re: Problem with r.basin in grass7 (Helmut Kudrnovsky)
- Re: d.out.file / d.save - Shell-script use issues (Glynn Clements)
- Re: A question before I embark on a programming exercise
(Glynn Clements)- Re: A question before I embark on a programming exercise
(Rainer M Krug)- Re: A question before I embark on a programming exercise
(Moritz Lennert)- Re: d.out.file / d.save - Shell-script use issues
(Nikos Alexandris)- Re: d.out.file / d.save - Shell-script use issues (Peter L?we)
(Thomas Adams)
Message: 1
Date: Thu, 14 Nov 2014 02:34:02 +0000
To: “hazel smith” hazel.smith@aecom.com, “gv1978”
gv1978@gmail.com, “grass user request”
grass-user-request@lists.osgeo.org, “grass user”
grass-user@lists.osgeo.org, “hr” hr@redr.org.uk, “hcpickard”
hcpickard@gmail.com, “Hertha Taverner Wood” herthat@gmail.com
Subject: [GRASS-user] FW:11/14/2014 2:34:02 AM 4
Message-ID: 543442A5277F3033D1E770CCEE1F6E4D@xwn2.com
Content-Type: text/plain; charset=“iso-8859-1”http://www.sansebastianradio.com/sqgruarc/rkemiqdhspxdpdqqqiphr.pvywnulkxerfsnggv
Rebecca Stedham
An HTML attachment was scrubbed…
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20141114/5118f922/attachment-0001.html
Message: 2
Date: Fri, 14 Nov 2014 01:02:26 -0800 (PST)
To: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] Problem with r.basin in grass7
Message-ID: 1415955746311-5172960.post@n6.nabble.com
Content-Type: text/plain; charset=us-asciiAndrea Timmermann wrote
and got:
Downloading precompiled GRASS Addons <r.stream.distance>…
File "C:\Program Files (x86)\GRASS GIS
7.1.svn/scripts/g.extension.py", line 1083, in <module>
sys.exit(main())
7.1.svn/scripts/g.extension.py", line 1071, in main
install_extension(xmlurl)
7.1.svn/scripts/g.extension.py", line 479, in
install_extension
ret += install_extension_win(module)
7.1.svn/scripts/g.extension.py", line 709, in
zfobj = zipfile.ZipFile(fo)
7.1.svn\Python27\lib\zipfile.py", line 766, in init
self._RealGetContents()
7.1.svn\Python27\lib\zipfile.py", line 807, in
_RealGetContents
raise BadZipfile, "File is not a zip file"
zipfile.BadZipfile: File is not a zip filethe r.stream.* addons are now back again for winGRASS, see e.g.
http://wingrass.fsv.cvut.cz/grass71/addons/grass-7.1.svn/thanks to Martin.
best regards
HelmutView this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-r-basin-in-grass7-tp5169155p5172960.html
Message: 3
Date: Fri, 14 Nov 2014 09:31:37 +0000
To: Vaclav Petras wenzeslaus@gmail.com
Cc: GRASS user list grass-user@lists.osgeo.org, Peter Löwe
peter.loewe@gmx.de
Subject: Re: [GRASS-user] d.out.file / d.save - Shell-script use
issues
Message-ID: 21605.52217.861520.833039@cerise.gclements.plus.com
Content-Type: text/plain; charset=us-asciiVaclav Petras wrote:
I kindly ask command line users of d.* commands, especially those using d.*
commands in scripts, to test and participate in discussions concerning d.*
commands in GRASS GIS 7. For example, d.out.file was added (relatively)
lately to 7 and there is new command d.to.rast. They are designed to work
with wxGUI (including wx monitors).Could you choose a different prefix for these commands, and leave d.*
for display commands?–
Glynn Clements glynn@gclements.plus.com
Message: 4
Date: Fri, 14 Nov 2014 09:40:35 +0000
To: Moritz Lennert mlennert@club.worldonline.be
Cc: “grass-user@lists.osgeo.org” grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] A question before I embark on a programming
exercise
Message-ID: 21605.52755.604436.245535@cerise.gclements.plus.com
Content-Type: text/plain; charset=us-asciiMoritz Lennert wrote:
r.mapcalc down_id = if(dir=1, id[1,1], if(dir=2, id[0,1], if(dir=3,
id[-1,1] … etcr.mapcalc follows C expression syntax; "="is assignment, “==” is the
equality test.–
Message: 5
Date: Fri, 14 Nov 2014 11:21:15 +0100
To: Glynn Clements glynn@gclements.plus.com
exercise
Message-ID: m2ppcqulpg.fsf@krugs.de
Content-Type: text/plain; charset=“us-ascii”Glynn Clements glynn@gclements.plus.com writes:
equality test.In this case shouldn’t it be
| r.mapcalc down_id = if(dir==1, id[1,1], if(dir==2, id[0,1], if(dir==3, id[-1,1] … etc
`----with “==” after the dir?
Rainer
Rainer M. Krug
email: Rainerkrugsde
PGP: 0x0F52F982
A non-text attachment was scrubbed…
Type: application/pgp-signature
Desc: not available
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20141114/b1be3185/attachment-0001.pgp
Message: 6
Date: Fri, 14 Nov 2014 12:36:20 +0100
To: Rainer M Krug Rainer@krugs.de, Glynn Clements
exercise
Message-ID: 5465E934.4020605@club.worldonline.be
Content-Type: text/plain; charset=windows-1252; format=flowedOn 14/11/14 11:21, Rainer M Krug wrote:
Yes, that’s what Glynn is saying. Sorry, I wrote this example too quickly.
Moritz
Message: 7
Date: Fri, 14 Nov 2014 14:07:08 +0200
Cc: GRASS user list grass-user@lists.osgeo.org, Peter L?we
peter.loewe@gmx.de
issues
Message-ID: 20141114120708.GA11735@tpx1c2g
- Vaclav Petras wenzeslaus@gmail.com [2014-11-12 09:35:32 -0500]:
with wxGUI (including wx monitors).I quickly ran through most d.* commands (except for the d.vect* stuff).
Some notes:d.erase: I would like to do
d.erase black
. Black is a good
background color.d.info -g: Maybe change the -g’s flag description? ‘s/geographic//’ to
avoid confusion(s) (geographic vs. projected, etc.)?d.rast.edit: let instructions/mouse actions explained inside a
wx-monitor?For the d.what* commands, the icons to perform such queries exist
already in a wx-Monitor, right?Isn’t it possible to merge d.out.file and d.to.rast? Maybe instruct
“to.rast” with a flag or an explicit output name?Nikos
Message: 8
Date: Fri, 14 Nov 2014 13:45:59 +0100
To: “Nikos Alexandris” nik@nikosalexandris.net
issues
Message-ID:
trinity-337e5b41-f6ee-4f8d-9991-3b7d0ec2781a-1415969159733@3capp-gmx-bs37Content-Type: text/plain; charset=UTF-8
Hi Nikos, dear all,
I strongly support this. The cumbersome re-import of the monitor content to use as a raster layer (d.to.file → r.in.gdal → r.composite) could be avoided.
Peter
Message: 9
Date: Fri, 14 Nov 2014 07:05:41 -0700
Cc: “grass-user@lists.osgeo.org” grass-user@lists.osgeo.org, Glynn
exercise
Message-ID:
CAGxgkWhNqc_ho7yqagQ5etTp6Um2H9ZHxLH=qOy3W8Y4t7dmnA@mail.gmail.com
Content-Type: text/plain; charset=“utf-8”Glynn & Rainer,
YES, absolutely – I caught that and made it ‘==’ instead of ‘=’. When
typing quickly, I sometimes make that mistake and then have to correct
myself. But fundamentally, Moritz’ approach worked very well and produced
what I needed. I have a more difficult problem now, something I think I can
only resolve by using higher resolution data. But, that is OK, too, because
I should get better modeling results in the end. I’m trying to create my
own approach to generating the file, that when used by the model, gives
essentially the same results.The folks who wrote the model and software to generate this runoff/flow
connectivity file between pixels, found that with coarser pixel
resolutions, the connection between pixels was badly distorted, in
physically unreasonable ways. I don’t have their original code, so I can
not use it, plus, I really want to model at much finer spatial resolutions
anyway, where the problem should go vanish.So, I just need to use higher resolution DEM data, which I have, rather
than trying to do things at the default 4km resolution.One question I have: it would be very nice to be able to show how the
pixels are connected using vectors, essentially the drainage network. Any
thoughts how to do this?Regards,
id[-1,1] … etc
Rainer
Rainer M. Krug
PGP: 0x0F52F982
http://lists.osgeo.org/mailman/listinfo/grass-user-------------- next part --------------
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20141114/ab2e2770/attachment.html
http://lists.osgeo.org/mailman/listinfo/grass-userEnd of grass-user Digest, Vol 103, Issue 23
