[GRASS-user] Grass 6.4, Opensuse 13.1/13.2
Dear all,
A couple of weeks ago I made the mistake of upgrading Opensuse on this 32 Toshiba Laptop to 13.2. Grass failed to work with error messages indicating NumPy had not been installed. It had been installed but did not contain the files Grass was looking for. Attempts at removing and re-installing NumPy all produced the same incomplete file set. (i586 installation)
I have reverted to Opensuse 13.1 and now have another non working version Grass 6.4
Traceback (most recent call
GRASS 6.4.3 (South_Oxfordshire):~ > Traceback (most recent call last):
File “/opt/grass/etc/wxpython/wxgui.py”, line 139, in
sys.exit(main())
File “/opt/grass/etc/wxpython/wxgui.py”, line 132, in main
app = GMApp(workspaceFile)
File “/opt/grass/etc/wxpython/wxgui.py”, line 45, in init
wx.App.init(self, False)
File “/usr/lib/python2.7/site-packages/wx-2.8-gtk2-unicode/wx/_core.py”, line 7981, in init
self._BootstrapApp()
File “/usr/lib/python2.7/site-packages/wx-2.8-gtk2-unicode/wx/_core.py”, line 7555, in _BootstrapApp
return core.PyApp__BootstrapApp(*args, **kwargs)
File “/opt/grass/etc/wxpython/wxgui.py”, line 78, in OnInit
workspace = self.workspaceFile)
File “/opt/grass/etc/wxpython/lmgr/frame.py”, line 111, in init
self.toolbars = { ‘workspace’ : LMWorkspaceToolbar(parent = self),
File “/opt/grass/etc/wxpython/lmgr/toolbars.py”, line 40, in init
self.InitToolbar(self._toolbarData())
File “/opt/grass/etc/wxpython/gui_core/toolbars.py”, line 96, in InitToolbar
self.CreateTool(*tool)
File “/opt/grass/etc/wxpython/gui_core/toolbars.py”, line 120, in CreateTool
shortHelp, longHelp)
File “/usr/lib/python2.7/site-packages/wx-2.8-gtk2-unicode/wx/_controls.py”, line 3764, in AddLabelTool
shortHelp, longHelp, clientData)
File “/usr/lib/python2.7/site-packages/wx-2.8-gtk2-unicode/wx/_controls.py”, line 3686, in DoAddTool
return controls.ToolBarBase_DoAddTool(*args, **kwargs)
ValueError: invalid null reference in method ‘ToolBarBase_DoAddTool’, expected argument 4 of type ‘wxBitmap const &’
I am assuming both the errors in 13.2 and now in 13.1 are due to installation issues. Grass 6.4 worked well in 13.1 until I upgraded. Can anyone help?
Thanks
Tim
Tim Southern
17, Park Close,
Sonning Common,
Oxfordshire
RG4 9RY
On 25 Nov 2014, at 20:00, grass-user-request@lists.osgeo.org wrote:
Send grass-user mailing list submissions to
grass-user@lists.osgeo.org
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
You can reach the person managing the list at
grass-user-owner@lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than “Re: Contents of grass-user digest…”
Today’s Topics:
  1. Re: Computing major and minor axes for polygons (Benjamin Ducke)
  2. Re: Computing major and minor axes for polygons (S?ren Gebbert)
  3. Re: Computing major and minor axes for polygons (Nikos Alexandris)
Message: 1
Date: Mon, 24 Nov 2014 22:50:46 +0100
To: grass-user grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] Computing major and minor axes for polygons
Message-ID: 5473A836.5030305@fastmail.fm
Content-Type: text/plain; charset=utf-8
Right, a PCA of the polygon vertices, I assume?
Maybe “v.to.db” could be enhanced to allow it to upload
the lengths of the first two/three components to the
attribute table?
For a quick fix, I solved the problem in a shell script using
a crude approximation. FWIW:
0. Set major axis length=-1
  1. Rotate polygon by 10? (v.transform)
  2. Fit region to polygon (g.region vect=).
  3. Get width of region. If it is greater than major axis length,
    set “major axis length = width”
  4. Repeat from 1, until polygon has been rotated 350?
  5. Minor axis length = height of current region.
Like I said, it’s just a crude approximation (precision can
be increased by using smaller rotation steps) and slow, too.
But it’s good enough for my purposes, which is basically to
calculate “elongation=len(major)/len(min)”.
Best,
Ben
On 24/11/14 19:27, S?ren Gebbert wrote:
IIRC is the code to compute the major and minor axes already in GRASS.
You need to perform a Karhunen-Loewe-Transformation for each Polygon.
This is also known as principal components analysis.
Best regards
Soeren
Am 21.11.2014 23:33 schrieb “Benjamin Ducke” <benducke@fastmail.fm
mailto:benducke@fastmail.fm>:
Hi All –
Does anybody here know of an existing GRASS modules that
will compute the major and minor axes for the polygons of
a vector map?
Thanks and best,
Ben
grass-user@lists.osgeo.org mailto:grass-user@lists.osgeo.org
Dr. Benjamin Ducke
{} Geospatial Consultant
} GIS Developer
Spatial technology for the masses, not the classes:
experience free and open source GIS at http://gvsigce.org
Message: 2
Date: Mon, 24 Nov 2014 23:44:29 +0100
To: Benjamin Ducke benducke@fastmail.fm
Cc: grass-user grass-user@lists.osgeo.org
Message-ID:
CAPHDReJy+aLKPEZThfCd+8M935qGiLD1f-yNhrjemZ-s8RUmog@mail.gmail.com
Content-Type: text/plain; charset=UTF-8
Hi Ben,
2014-11-24 22:50 GMT+01:00 Benjamin Ducke benducke@fastmail.fm:
Exactly, create a covariance matrix from the vertices coordinates of
each polygon
and compute the eigenvectors and eigenvalues of these matrices.
Best regards
Soeren
attribute table?
Best,
Ben
Best regards
Soeren
Hi All –
a vector map?
Thanks and best,
Ben
Dr. Benjamin Ducke
} GIS Developer
Message: 3
Date: Tue, 25 Nov 2014 19:10:38 +0200
To: grass-user@lists.osgeo.org
Message-ID: 5db8e3e250d0adde57c6a9628ba5611f@nikosalexandris.net
Content-Type: text/plain; charset=UTF-8; format=flowed
attribute table?
Wow, What a smart approach! :slight_smile:
Nikos
End of grass-user Digest, Vol 103, Issue 42
Hi Tim,
I will have a look at this and report back.
Angelos
On 11/29/2014 03:32 PM, Tim Southern wrote:
Dear all,
File "/opt/grass/etc/wxpython/wxgui.py", line 139, in <module>
sys.exit(main())
File "/opt/grass/etc/wxpython/wxgui.py", line 132, in main
File "/opt/grass/etc/wxpython/wxgui.py", line 45, in __init__
wx.App.__init__(self, False)
File "/usr/lib/python2.7/site-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 7981, in __init__
File "/usr/lib/python2.7/site-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File "/opt/grass/etc/wxpython/wxgui.py", line 78, in OnInit
File "/opt/grass/etc/wxpython/lmgr/frame.py", line 111, in __init__
self.toolbars = { 'workspace' : LMWorkspaceToolbar(parent = self),
File "/opt/grass/etc/wxpython/lmgr/toolbars.py", line 40, in __init__
File "/opt/grass/etc/wxpython/gui_core/toolbars.py", line 96, in InitToolbar
File "/opt/grass/etc/wxpython/gui_core/toolbars.py", line 120, in CreateTool
File "/usr/lib/python2.7/site-packages/wx-2.8-gtk2-unicode/wx/_controls.py", line 3764, in AddLabelTool
File "/usr/lib/python2.7/site-packages/wx-2.8-gtk2-unicode/wx/_controls.py", line 3686, in DoAddTool
return _controls_.ToolBarBase_DoAddTool(*args, **kwargs)
ValueError: invalid null reference in method 'ToolBarBase_DoAddTool', expected argument 4 of type 'wxBitmap const &'
Thanks
Tim
Tim Southern
17, Park Close,
Sonning Common,
Oxfordshire
RG4 9RY
or, via email, send a message with subject or body 'help' to
than "Re: Contents of grass-user digest..."
Today's Topics:
Message: 1
To: grass-user <grass-user@lists.osgeo.org>
Message-ID: <5473A836.5030305@fastmail.fm>
Maybe "v.to.db" could be enhanced to allow it to upload
attribute table?
   set "major axis length = width"
Like I said, it's just a crude approximation (precision can
But it's good enough for my purposes, which is basically to
calculate "elongation=len(major)/len(min)".
Best,
Ben
Best regards
Soeren
Am 21.11.2014 23:33 schrieb "Benjamin Ducke" <benducke@fastmail.fm
<mailto:benducke@fastmail.fm>>:
    Hi All --
    a vector map?
    Thanks and best,
    Ben
    grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
Dr. Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
Message: 2
To: Benjamin Ducke <benducke@fastmail.fm>
Cc: grass-user <grass-user@lists.osgeo.org>
Message-ID:
  <CAPHDReJy+aLKPEZThfCd+8M935qGiLD1f-yNhrjemZ-s8RUmog@mail.gmail.com>
Hi Ben,
2014-11-24 22:50 GMT+01:00 Benjamin Ducke <benducke@fastmail.fm>:
each polygon
Best regards
Soeren
attribute table?
Best,
Ben
Best regards
Soeren
    Hi All --
    a vector map?
    Thanks and best,
    Ben
Dr. Benjamin Ducke
{*} GIS Developer
Message: 3
To: <grass-user@lists.osgeo.org>
Message-ID: <5db8e3e250d0adde57c6a9628ba5611f@nikosalexandris.net>
attribute table?
Nikos
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
Problem fixed on both openSUSE 13.1 and 13.2
Can you please confirm?
On 11/30/2014 01:43 AM, Angelos Tzotsos wrote:
Hi Tim,
Angelos
Dear all,
sys.exit(main())
Thanks
Tim
Tim Southern
17, Park Close,
Sonning Common,
Oxfordshire
RG4 9RY
Today's Topics:
Message: 1
attribute table?
Best,
Ben
Best regards
Soeren
    Hi All --
    a vector map?
    Thanks and best,
    Ben
Dr. Benjamin Ducke
{*} GIS Developer
Message: 2
Message-ID:
Hi Ben,
each polygon
Best regards
Soeren
attribute table?
Best,
Ben
Best regards
Soeren
    Hi All --
    a vector map?
    Thanks and best,
    Ben
Dr. Benjamin Ducke
{*} GIS Developer
Message: 3
attribute table?
Nikos
Angelos Tzotsos
