[GRASS-user] GRASS 6.4.RC3 GUI not starting on windows & GRASS 7 not launching at all
Hi everyone,
I downloaded the Windows binary for Grass 6.4.3RC3 (dated April 20, 2013, available on http://grass.osgeo.org/grass64/binary/mswindows/native/) and installed it on my Windows PC (6-4 bit, running Windows 7).
I got the following error message on start-up.
Starting GRASS …
File “C:\GRASS643RC3\Python27\lib\site.py”, line 563, in
main()
File “C:\GRASS643RC3\Python27\lib\site.py”, line 545, in main
known_paths = addusersitepackages(known_paths)
File “C:\GRASS643RC3\Python27\lib\site.py”, line 278, in addusersitepackages
user_site = getusersitepackages()
File “C:\GRASS643RC3\Python27\lib\site.py”, line 253, in getusersitepackages
user_base = getuserbase() # this will also set USER_BASE
File “C:\GRASS643RC3\Python27\lib\site.py”, line 243, in getuserbase
USER_BASE = get_config_var(‘userbase’)
File “C:\GRASS643RC3\Python27\lib\sysconfig.py”, line 472, in get_config_var
return get_config_vars().get(name)
File “C:\GRASS643RC3\Python27\lib\sysconfig.py”, line 405, in get_config_vars
import re
File “C:\GRASS643RC3\Python27\lib\re.py”, line 105, in
import sre_compile
File “C:\GRASS643RC3\Python27\lib\sre_compile.py”, line 14, in
import sre_parse
File “C:\GRASS643RC3\Python27\lib\sre_parse.py”, line 17, in
from sre_constants import *
File “C:\GRASS643RC3\Python27\lib\sre_constants.py”, line 18, in
from _sre import MAXREPEAT
ImportError: cannot import name MAXREPEAT
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue…
I also tried with the most recent WinGRASS binary snapshot: 6.4.3svn-r56225, and got the same result.
I also tried download and installing the most recent binary snapshot of winGRASS 7: r56229, and that wouldn’t start at all.
I have winGRASS 6.4.3 RC2 working fine on my PC. A previous binary snapshot of winGRASS 7 (about a month old) was also working fine, but I uninstalled it to install the most recent version.
I appreciate any ideas you have on what might be going wrong.
Thank you,
Hanan
This message has been scanned for malware by Websense. www.websense.com
I had the same problem and found out that a system-wide Python
installation (2.7.2, independent of GRASS) caused the trouble.
Uninstalling the system-wide python helped, but this may not be an
option for many users, because other software might rely on a
particular python version installed.
Markus M
On Mon, May 13, 2013 at 1:29 PM, Hanan Karam
<HananKaram@esinternational.com> wrote:
Hi everyone,
Starting GRASS ...
  File "C:\GRASS643RC3\Python27\lib\site.py", line 563, in <module>
    main()
  File "C:\GRASS643RC3\Python27\lib\site.py", line 545, in main
  File "C:\GRASS643RC3\Python27\lib\site.py", line 278, in
addusersitepackages
  File "C:\GRASS643RC3\Python27\lib\site.py", line 253, in
getusersitepackages
  File "C:\GRASS643RC3\Python27\lib\site.py", line 243, in getuserbase
    USER_BASE = get_config_var('userbase')
  File "C:\GRASS643RC3\Python27\lib\sysconfig.py", line 472, in
get_config_var
  File "C:\GRASS643RC3\Python27\lib\sysconfig.py", line 405, in
get_config_vars
    import re
  File "C:\GRASS643RC3\Python27\lib\re.py", line 105, in <module>
    import sre_compile
  File "C:\GRASS643RC3\Python27\lib\sre_compile.py", line 14, in <module>
    import sre_parse
  File "C:\GRASS643RC3\Python27\lib\sre_parse.py", line 17, in <module>
  File "C:\GRASS643RC3\Python27\lib\sre_constants.py", line 18, in <module>
Hit RETURN to continue...
Thank you,
Hanan
grass-user mailing list
grass-user@lists.osgeo.org
I just want to confirm that replacing my system-wide Python installation with version 2.7.4, instead of 2.7.2, solved the problem.
Thank you very much
Hanan
-----Original Message-----
From: Markus Metz [mailto:markus.metz.giswork@gmail.com]
Sent: 13 May 2013 16:11
To: Hanan Karam
Cc: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] GRASS 6.4.RC3 GUI not starting on windows & GRASS 7 not launching at all
I had the same problem and found out that a system-wide Python installation (2.7.2, independent of GRASS) caused the trouble.
Uninstalling the system-wide python helped, but this may not be an option for many users, because other software might rely on a particular python version installed.
Markus M
On Mon, May 13, 2013 at 1:29 PM, Hanan Karam <HananKaram@esinternational.com> wrote:
Hi everyone,
2013, available on
Starting GRASS ...
    main()
addusersitepackages
getusersitepackages
get_config_var
get_config_vars
    import re
    import sre_compile
<module>
    import sre_parse
<module>
<module>
of winGRASS 7: r56229, and that wouldn't start at all.
Thank you,
Hanan
www.websense.com
thanks for the confirmation.
(@devs: where to put wingrass release notes these days?)
MarkusM:
trouble.
for them the GRASS python.exe can be set with full path name in
C:\Program Files\GRASS GIS...\etc\env.bat:
set GRASS_PYTHON=%GISBASE%\extrabin\python.exe
Not exactly user-friendly, but simple enough once you know
what to do. any reason not to make the full path the default?
Hamish
On Mon, May 13, 2013 at 8:39 PM, Hanan Karam
Excellent: added to
http://grasswiki.osgeo.org/wiki/WinGRASS_errors
markusN
