[GRASS-user] GRASS 6.4 RC4 freezing—.dbf problem?
One of my projects keeps causing GRASS to freeze when I resize the map window. I am using GRASS 6.4 RC 4 on OS X. I tried another project and it resizes fine. I think I know what the problem is. I used the spreadsheet in Openoffice to adjust a .dbf file. The STR_1 column originally read #1 %64 @"Cat. 64". I needed the Cat. 64 for a label on my map so I edited the column to read just Cat. 64. Is grass looking for the #1 %64 with the quotation marks? Would this cause GRASS to freeze and would the problem be solved by replacing the codes. If this is the case, can I add a column that will just be Cat. 64 with no ill effects, and use that as my label?
Any advice will be appreciated
