[GRASS-user] grass 6.4 rc5 and python scripting
Hello list
I compiled grass-6.4.0RC5 (downloaded a tarball from the main site).
I'd like to learn about scripting grass with python.
Following the first sample script at the GRASS Python scripting
library (http://download.osgeo.org/grass/grass6_progman/pythonlib.html)
I created a test file called teste.py, and placed it on the Desktop.
When I try to run it inside a GRASS session I am geting the following
error:
GRASS 6.4.0RC5 (aeigT3):~/Desktop > ./teste.py
sh: teste.py: not found
  File "/usr/local/grass-6.4.0RC5/etc/wxpython/gui_modules/menuform.py",
line 1931, in <module>
    GrassGUIApp( grassTask( sys.argv[1] ) ).MainLoop()
line 335, in __init__
    xml.sax.parseString( getInterfaceDescription( grassModule ) ,
processTask( self ) )
line 1748, in getInterfaceDescription
    raise IOError, _("Unable to fetch interface description for
command '%s'.") % cmd
IOError: Unable to fetch interface description for command 'teste.py'.
The file contents are just a copy+paste from the online example. Can
someone point me to the cause of the error?
Thanks in advance
___________________________ ___ __
Ricardo Garcia Silva
2009/6/30 Ricardo Filipe Soares Garcia da <ricardo.garcia.silva@gmail.com>:
error:
to launch wxGUI interface you need to copy teste.py to
$GISBASE/scripts. Anyway CLI works in every case
./teste.py --help
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Thanks for your help
Now I'll get on with the program!
Hopefully I'll be able to build a "script that can find the nearest
hospital to an accident site on a vector network" working :wink:
On Tue, Jun 30, 2009 at 2:51 PM, Martin Landa<landa.martin@gmail.com> wrote:
error:
./teste.py --help
Martin
Please help: What could be missing?
Compiling on ubuntu 9.04 64bit (linux mint)
Errors in:
/usr/local/src/grass6_devel/lib/db/sqlp
/usr/local/src/grass6_devel/db/drivers/ogr
/usr/local/src/grass6_devel/db/drivers/dbf
/usr/local/src/grass6_devel/raster/r.mapcalc
Thanks a lot!
Achim
with:
CFLAGS="-O3 -msse3 -march=core2 -Wall" LDFLAGS="-s" ./configure \
       --enable-64bit \
       --with-libs=/usr/lib64 \
       --with-fftw \
       --with-cxx \
       --with-sqlite \
       --with-cairo \
       --with-cairo-includes=/usr/include/cairo \
       --with-freetype \
       --with-freetype-includes=/usr/include/freetype2 \
       --with-proj-share=/usr/share/proj \
       --with-geos \
       --with-python=/usr/bin/python2.6-config \
       --with-wxwidgets=/usr/bin/wx-config \
       --with-tcltk-includes=/usr/include/tcl8.5 \
       --with-readline
GRASS is now configured for: x86_64-unknown-linux-gnu
  Source directory: /usr/local/src/grass6_devel
  Build directory: /usr/local/src/grass6_devel
  Installation directory: ${prefix}/grass-6.5.svn
  Startup script in directory: ${exec_prefix}/bin
  C compiler: gcc -O3 -msse3 -march=core2 -Wall C++ compiler: c++ -g -O2
  Building shared libraries: yes
  64bit support: yes
  OpenGL platform: X11
  MacOSX application: no
  NVIZ: yes
  BLAS support: no
  C++ support: yes
  Cairo support: yes
  DWG support: no
  FFMPEG support: no
  FFTW support: yes
  FreeType support: yes
  GDAL support: yes
  GEOS support: yes
  GLw support: no
  JPEG support: yes
  LAPACK support: no
  Large File support (LFS): yes
  Motif support: no
  MySQL support: no
  NLS support: no
  ODBC support: no
  OGR support: yes
  OpenGL support: yes
  PNG support: yes
  PostgreSQL support: no
  Python support: yes
  Readline support: yes
  SQLite support: yes
  Tcl/Tk support: yes
  wxWidgets support: yes
  TIFF support: yes
  X11 support: yes
Errors in:
On 30/06/09 12:58, Ricardo Filipe Soares Garcia da wrote:
Hello list
error:
In order for g.parser to work, the file teste.py needs to be in your PATH. So, you can do something like this:
export PATH=$PATH:.
./teste.py
Moritz
2009/6/30 achim <ak7@jupiter.uni-freiburg.de>:
Errors in:
you have to send error log from 'lib/db/sqlp', otherwise nobody can help you.
Martin
> error:
PATH.
This is actually a bug in G_parser() and G_gui(). menuform.py is being
passed the base filename rather than the complete path. There isn't
any other reason why the script needs to be in the path.
