[GRASS-user] GRASS 7.0.0
Dear Grass users,
recently I installed GRASS 7.0.0 on ubuntu 14.04 (32 bits). When I tried to open by typing grass70 command I get the following error message: python: can’t open file ‘/usr/lib/grass70/gui/wxpython/gis_set.py’: [Errno 2] No such file or directory
Received EXIT message from GUI.
GRASS is not started. Bye
I also have version 6.4.3 pefectly working from before, but I would like to migrate to Grass 70 as soon as posible. Any suggestions how to solve this issue?
thanks in advance…
Rengifo Ortega
Hi Rengifo,
On Thu, Aug 21, 2014 at 7:28 AM, Rengifo Ortega <rengifoo@yahoo.de> wrote:
Dear Grass users,
can you please describe how did you installed GRASS GIS? Compiled yourself? Is the gis_set.py file present somewhere?
thanks in advance…
Rengifo Ortega
grass-user mailing list
grass-user@lists.osgeo.org
message: python: can't open file
'/usr/lib/grass70/gui/wxpython/gis_set.py': [Errno 2] No such file or
directory Received EXIT message from GUI. GRASS is not started.
since you are using Ubuntu 14.04 I might recommend this script to
install the GRASS 7.0nightly package and sample dataset:
https://trac.osgeo.org/osgeo/browser/livedvd/gisvm/trunk/bin/install_grass7.sh
Some minor adjustments would be needed, but if you follow it line
by line, set your account name, and ignore the "Desktop GIS" directory
stuff I think it will be ok. It puts the data in /usr/local/share/grass,
you may wish to just put it in your home directory.
It sets things up so that you can run in parallel with GRASS 6.4
packages, i.e. have both versions installed at the same time. (GRASS
6.4.4 is now available for 14.04 in the UbuntuGIS ppa)
One thing currently broken in there is the wxGUI's parsing of g.version
output, so the splash screen comes back as "Version ?", but that's just
cosmetic.
regards,
Hamish
error message: python: can't open file
directory
(make sure the grass70-gui package is installed too)
H
Hi Vaclav, Thank for you quick reply.
yourself?
Yes, I compiled Grass70 following partly the instructions give in this
official site: http://grasswiki.osgeo.org/wiki/Compile_and_Install
Apparently not. I use the following command dpkg -l | grep gis_set.py,
but without results. Do you other manner t find out if the gis_set.py
in present? I would appreciate it.
On to., 2014-08-21 at 09:08 -0400, Vaclav Petras wrote:
Hi Rengifo,
wrote:
> Dear Grass users,
directory
> thanks in advance..
> Rengifo Ortega
Hi Hamish,
Thanks a lot for taking the time to look trough my problem with the
grass70 installation. Your script did the trick. I have grass70 up and
running, together with grass 64.
Thanks a lot
best regards.
Rengifo
cosmetic.
regards,
Hamish
