[GRASS-user] GRASS 7.0 svn location/map creation using console
Hi list,
I am running remotely GRASS 7.0 from svn on a workstation using ssh.
As classical location/mapset prompt is not displayed in 7.0,
how can I create new locations/mapset using console?
Thanks in advance,
regards,
Enrico Gallo
Start GRASS "somehow" and run
g.mapset -c mapset=new
j
On Wed, Jul 29, 2009 at 09:25:18PM +0200, Enrico Gallo wrote:
Hi list,
Thanks in advance,
regards,
Enrico Gallo
grass-user mailing list
grass-user@lists.osgeo.org
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/JachymCepicky.pgp
Key fingerprint: 0C6D 0EAE 76BD 506C F299 ED8A C8AB 74B8 08D4 E08F
2009/7/30 Jachym Cepicky <jachym.cepicky@gmail.com>:
j
hi Jachym , hi list
AFAIK, g.mapset -c is OK for new mapset in existing location, but
what about new location?
We have to use ssh -X and gui?
Enrico Gallo
Hi list,
Thanks in advance,
regards,
Enrico Gallo
Jachym Cepicky
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
iEYEARECAAYFAkpxJW0ACgkQyKt0uAjU4I9zswCfUBvjDl3SMLyF8YDwA2bcVb9/
z/oAni+vns+9bUoJQEd4iqYe0RypgWlQ
=zSM8
-----END PGP SIGNATURE-----
Jachym Cepicky:
> j
Enrico Gallo wrote:
hi Jachym , hi list
Enrico Gallo
what about "g.proj location=NameForNewLocation"
Nikos
>> Hi list,
>> Thanks in advance,
>> regards,
>> Enrico Gallo
Jachym Cepicky:
> > j
Enrico Gallo wrote:
> hi Jachym , hi list
> Enrico Gallo
Sorry, I forgot the "-c" flag, so:
g.proj -c location=...
Nikos
> >> Hi list,
> >> Thanks in advance,
> >> regards,
> >> Enrico Gallo
please try starting grass with:
grass -text
cheers
Ivan
> j
hi Jachym , hi list
Enrico Gallo
>> Hi list,
>> Thanks in advance,
>> regards,
>> Enrico Gallo
>> _______________________________________________
> Jachym Cepicky
> =zSM8
Ti prego di cercare di non inviarmi files .dwg, .doc, .xls, .ppt.
Preferisco formati liberi.
Please try to avoid to send me .dwg, .doc, .xls, .ppt files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Perugia (Italy)
Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
e-mail: marchesini@unipg.it
        ivan.marchesini@gmail.com
fax (home): +39(0)5782830887
jabber: geoivan73@jabber.org
skype: geoivan73
Hi list,
thanks for useful your suggestions.
2009/7/30 Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>:
Jachym Cepicky:
> > j
I am sorry, but the problem how we create first location only using
console is still opened, IMHO
Consider GRASS 5.x & 6.x displayed a prompt, and 7.x no more ..
I can use g.proj and g.mapset only inside GRASS environment,
but if I have non correct location I cannot enter in GRASS 7.x from
console, using -text flag, of course
thanks in advance
Enrico Gallo
[CC to grass-dev]
Without the GUI, you currently have to create a new location manually,
e.g.:
olddbase=`g.gisenv get=GISDBASE`
g.gisenv set=GISDBASE=/path/to/database
g.proj -c location=newlocation ...
g.gisenv set=GISDBASE=$olddbase
g.mapset -c gisdbase=/path/to/database location=newlocation mapset=newmapset
g.mapset gisdbase=/path/to/database location=newlocation mapset=newmapset
g.region -d
Note that GRASS 7 includes a dummy location at $GISDBASE/demolocation;
this can be used to get into GRASS, provided that you're the owner of
the GRASS installation (probably root).
For developers:
1. init.{sh,py} need an option to create a new database/location/mapset
without using the GUI.
2. g.proj should have a database= option so that -c can create a new
database along with the location.
3. g.mapset complains if the current database/location/mapset aren't
valid; it should probably be changed to use G_no_gisinit() to handle
this.
