Nearly everything downloaded and installed from the dnf install file except for the proj-epsg item. Nevertheless, I went ahead with the ./configure script then was shot down by the “couldn’t find the TIFF” item. Evidently dnf install can’t find it and Fedora 33 doesn’t have it on my machine. (I used the “Everything” option, although I chose only some of the items). I attempted to use dnf to find TIFF but it failed.
If TIFF is related to the protocol for displaying *.tiff images then I’m confused. Or if there are some other instructions for grass-7.8.5 on Fedora I haven’t found them yet.
Ah, proj-epsg and proj-nad no longer exist (replaced by
proj-datumgrid* which was already listed there).
I have updated the wiki accordingly.
Nevertheless, I went ahead with the ./configure script then was shot down by the "couldn't find the TIFF" item.
Can you please post your "configure" command?
Evidently dnf install can't find it and Fedora 33 doesn't have it on my machine.
... there is the "libgeotiff-devel" RPM.
(I used the "Everything" option, although I chose only some of the items). I attempted to use dnf to find TIFF but it failed.
If TIFF is related to the protocol for displaying *.tiff images then I'm confused. Or if there are some other instructions for grass-7.8.5 on Fedora I haven't found them yet.
I am not sure what TIFF package you are looking for. Hence I'd need to
know your "configure" command.
I install from source, so cannot check. PROJ 7 needs Tiff and curl (to access
the CDN) over and above the sqlite3 requirement introduced by PROJ 6. Is the
install process pulling in PROJ > 6? I see 6.3.2 as the F33 current version,
but >= 7 would explain complaints about missing Tiff:
As a recent GRASS GIS-installation sufferer, I can explain what I did. Basically I followed Markus Neteler's instructions explicitly for installing 7.8.5. There were some small mistakes but he carefully corrected them. I used his instructions from the User Group regarding 7.8.5, and the instructions called for a two-step process (or three steps): download the 7.8.5 source tarball, use the script preparing for the compilation (which guarantees all the required software is installed), then run the compile, make, make install steps.
Michael Allen
Industrial Weather
763-777-1263
Sent with ProtonMail Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Wednesday, December 23, 2020 7:33 AM, Roger Bivand <Roger.Bivand@nhh.no> wrote:
