[GRASS-user] grass 7.8 failed to start
Hello,
I’m trying to run GRASS for the first time but got the error below:
Starting GRASS GIS…
File “/usr/local/grass78/gui/wxpython/core/globalvar.py”, line 49, in CheckWxVersion
parsed_version = list(map(int, split_ver))
ValueError: invalid literal for int() with base 10: ‘post2’
During handling of the above exception, another exception occurred:
File “/usr/local/grass78/gui/wxpython/gis_set.py”, line 34, in
from core import globalvar
File “/usr/local/grass78/gui/wxpython/core/globalvar.py”, line 237, in
hasAgw = CheckWxVersion([2, 8, 11, 0])
File “/usr/local/grass78/gui/wxpython/core/globalvar.py”, line 55, in CheckWxVersion
parsed_version = list(map(int, split_ver[:-1])) + [int(split_ver[-1][:i])]
ValueError: invalid literal for int() with base 10: ‘’
ERROR: Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.
To run GRASS GIS in text mode use the --text flag.
Use ‘–help’ for further options
grass78 --help
See also: https://grass.osgeo.org/grass78/manuals/helptext.html
Exiting…
what should be the solution for this?
Thanks a lot,
Asaf
On Mon, Nov 25, 2019 at 4:35 PM Asaf Lavi <laviasa@post.bgu.ac.il> wrote:
Hello,
I'm trying to run GRASS for the first time but got the error below:
did you compile it yourself?
Starting GRASS GIS...
  File "/usr/local/grass78/gui/wxpython/core/globalvar.py", line 49, in CheckWxVersion
ValueError: invalid literal for int() with base 10: 'post2'
  File "/usr/local/grass78/gui/wxpython/gis_set.py", line 34, in <module>
  File "/usr/local/grass78/gui/wxpython/core/globalvar.py", line 237, in <module>
  File "/usr/local/grass78/gui/wxpython/core/globalvar.py", line 55, in CheckWxVersion
ValueError: invalid literal for int() with base 10: ''
Use '--help' for further options
     grass78 --help
Exiting...
I suppose that it is addressed by this fix:
https://github.com/OSGeo/grass/commit/b7fb30a1da066e8864c8e36c5d55a93402e29dd0
which will be part of the upcoming GRASS GIS 7.8.2.
You may apply the change locally.
Best
