[GRASS-user] grass-7.9 does not find numpy
Starting grass-7.9 in a new location and mapset fails:
wxnviz.py: This module requires the NumPy module, which could not be imported. It probably is not installed (it's not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries.
   File "/usr/local/grass79/gui/wxpython/wxgui.py", line 172, in <module>
     sys.exit(main())
   File "/usr/local/grass79/gui/wxpython/wxgui.py", line 159, in main
     app = GMApp(workspaceFile)
   File "/usr/local/grass79/gui/wxpython/wxgui.py", line 53, in __init__
     wx.App.__init__(self, False)
   File "/usr/lib64/python2.7/site-packages/wx-3.0-gtk2/wx/_core.py", line 8628, in __init__
     self._BootstrapApp()
   File "/usr/lib64/python2.7/site-packages/wx-3.0-gtk2/wx/_core.py", line 8196, in _BootstrapApp
     return _core_.PyApp__BootstrapApp(*args, **kwargs)
   File "/usr/local/grass79/gui/wxpython/wxgui.py", line 104, in OnInit
     from lmgr.frame import GMFrame
   File "/usr/local/grass79/gui/wxpython/lmgr/frame.py", line 51, in <module>
     from lmgr.layertree import LayerTree, LMIcons
   File "/usr/local/grass79/gui/wxpython/lmgr/layertree.py", line 40, in <module>
     from wxplot.histogram import HistogramPlotFrame
   File "/usr/local/grass79/gui/wxpython/wxplot/histogram.py", line 23, in <module>
     import gui_core.wxlibplot as plot
   File "/usr/local/grass79/gui/wxpython/gui_core/wxlibplot.py", line 121, in <module>
     import numpy as np
ImportError: No module named numpy
Numpy is installed (by pip) in /usr/lib64/python3.7/site-packages/.
Please advise me how to make this installation visible to wxnviz.
Rich
Hello Rich,
perhaps related:
https://lists.osgeo.org/pipermail/grass-user/2019-July/080547.html
Vincent.
binaries.
<module>
     sys.exit(main())
__init__
OnInit
<module>
in <module>
23, in <module>
121, in <module>
     import numpy as np
Rich
grass-user mailing list
grass-user@lists.osgeo.org
On Thu, Aug 15, 2019 at 8:12 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
wxnviz.py: This module requires the NumPy module, which could not be imported. It probably is not installed (it’s not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries.
File “/usr/local/grass79/gui/wxpython/wxgui.py”, line 172, in
sys.exit(main())
File “/usr/local/grass79/gui/wxpython/wxgui.py”, line 159, in main
File “/usr/local/grass79/gui/wxpython/wxgui.py”, line 53, in init
wx.App.init(self, False)
File “/usr/lib64/python2.7/site-packages/wx-3.0-gtk2/wx/_core.py”, line 8628, in init
File “/usr/lib64/python2.7/site-packages/wx-3.0-gtk2/wx/_core.py”, line 8196, in _BootstrapApp
return core.PyApp__BootstrapApp(*args, **kwargs)
File “/usr/local/grass79/gui/wxpython/wxgui.py”, line 104, in OnInit
File “/usr/local/grass79/gui/wxpython/lmgr/frame.py”, line 51, in
File “/usr/local/grass79/gui/wxpython/lmgr/layertree.py”, line 40, in
File “/usr/local/grass79/gui/wxpython/wxplot/histogram.py”, line 23, in
File “/usr/local/grass79/gui/wxpython/gui_core/wxlibplot.py”, line 121, in
import numpy as np
but the gui is looking in /usr/lib64/python2.7/site-packages/
→ wrong python version
make sure wxpython for python3 is installed, make distclean, configure, make
HTH,
Markus M
On Thu, 15 Aug 2019, Vincent Bain wrote:
perhaps related:
Vincent,
Thanks for the URL, but it's not the same issue. There was no numpy to
upgrade.
Normally I build and install packages using the SlackBuilds.org scripts. For
reasons we could not explain, numpy3, scipy3, and python3-matplotlib refused
to build.
Needing these tools I used the command 'pip3 install numpy' because this
syntax tells pip3 to install numpy3 in the python-3.7/site-packages/
directory.
Rich
-> wrong python version
Markus M,
Thank you. I thought wxPython-3.0.2.0 worked for both Python versions.
Regardless, I'll get a wxPython4 package installed.
Best regards,
Rich
Markus M,
Now, wxPython-4.0.4 is installed and visible in
/usr/lib64/python3.7/site-packages/ but a rebuilt/reinstalled grass79 still
cannot find it:
$ grass79 Starting GRASS GIS...
ERROR: wxGUI requires wxPython. No module named wx
You can still use GRASS GIS modules in the command line or in Python.
ERROR: Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.
To run GRASS GIS in text mode use the --text flag.
Use '--help' for further options
      grass79 --help
See also: https://grass.osgeo.org/grass79/manuals/helptext.html
Exiting...
'wx' is found in several places:
# find / -name wx /usr/include/wx-3.0/wx
/usr/include/wx-2.8/wx
/usr/lib64/python3.7/site-packages/wx
/usr/lib64/wx
/usr/lib64/wx/include/gtk2-unicode-release-2.8/wx
/usr/lib64/wx/include/gtk2-unicode-3.0/wx
/home/rshepard/.grass7/wx
Could grass be looking for wxPython rather than wxPython4?
Rich
On Thu, Aug 15, 2019 at 10:50 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
Markus M,
cannot find it:
the grass startup script was not updated to enforce python3, fixed in master 83ba584e
git pull && make
should help
Markus M
$ grass79
Starting GRASS GIS…
Use ‘–help’ for further options
grass79 --help
Exiting…
‘wx’ is found in several places:
find / -name wx
/usr/lib64/wx
Rich
master 83ba584e
git pull && make
should help
Markus M,
I pulled new changed files from the git repo, saw a file name 'master...'.
Configured, built, and installed. Same error: grass is not finding wx.
Here, wx is seen in several places. Should there be more than one location
for this library? If so, where?
Rich
/usr/local/grass79/etc/VERSIONNUMBER is 7.9.dev 86354090c.
Rich
I just ran 'git pull' and configured, made, and installed the results. The
version number is the same as above and the initiation still exits because
it cannot find the GUI. wxPython-4.0.4 is installed.
What might I still be missing? I need to resolve this as soon as possible
and appeciate tests I can run to isolate the source of the problem.
Rich
On Mon, Aug 19, 2019 at 6:51 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
I just ran ‘git pull’ and configured, made, and installed the results. The
Please post the full error message.
Markus M
Markus M,
      grass79 --help
Also, when I send the 'git pull' command instead of seeing a list of
upgraded files I see this:
remote: Compressing objects: 100% (12/12), done.
remote: Total 24 (delta 14), reused 14 (delta 11), pack-reused 1
Unpacking objects: 100% (24/24), done.
From https://github.com/OSGeo/grass
    f6edaaffa..494d10b10 master -> origin/master
    0afea5a41..329fab952 releasebranch_7_6 -> origin/releasebranch_7_6
    d95f60bac..f582300b8 releasebranch_7_8 -> origin/releasebranch_7_8
Updating 86354090c..494d10b10
error: Your local changes to the following files would be overwritten by merge:
   lib/python/ctypes/ctypesgencore/parser/lextab.py
Please commit your changes or stash them before you merge.
Aborting
$ less /usr/local/grass79/etc/VERSIONNUMBER remains at 86354090c.
I'll run grass strictly from the command line now (as I did with versions
4.x) but it would be nice to have grass find wxPython-4.0.4 when starting.
HTH,
Rich
On Thu, Aug 22, 2019 at 5:57 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
Markus M,
      grass79 --help
run
git checkout lib/python/ctypes/ctypesgencore/parser/lextab.py
then update again. That glitch has been fixed recently but requires
this step (one time).
markusN
On Sun, 1 Sep 2019, Markus Neteler wrote:
run
markusN,
I pulled from the git repo yesterday morning, added them to my repo clone,
then configured, built, and installed grass7.9.svn. Testing using 'grass79
--gui' brought up that interface. So yesterday's pull must have included
lextab.py.
Thanks again,
Rich
