Hello,
Building grass 7 in ubuntu 9.10. Got an error I have seen before on this list.
GRASS 7.0.svn (demolocation):/usr/local/src/grass_trunk > g.list: error while loading shared libraries: libgdal.so.1: cannot open shared object file: No such file or directory
I put in
matthew@matthew-laptop:~$ dpkg -l|grep libgdal
ii libgdal1-1.5.0 1.5.4-4 Geospatial Data Abstraction Library
ii libgdal1-1.5.0-grass 1.5.4-3 GRASS extension for the GDAL library
ii libgdal1-dev 1.5.4-4 Geospatial Data Abstraction Library - Develo
matthew@matthew-laptop:~$ dpkg -l|grep libproj
ii libproj-dev 4.6.1-5 Cartographic projection library (development
ii libproj0 4.6.1-5 Cartographic projection library
it does exist but when in grass I do
GRASS 7.0.svn (demolocation):/usr/local/src/grass_trunk > whereis libgdal.so.1
libgdal.so:
libgdal:
GRASS 7.0.svn (demolocation):/usr/local/src/grass_trunk > wheris libgdal libgdal
No command ‘wheris’ found, did you mean:
Command ‘whereis’ from package ‘util-linux’ (main)
wheris: command not found
GRASS 7.0.svn (demolocation):/usr/local/src/grass_trunk > whereis libgdal libgdal
libgdal:
libgdal:
I don’t think it can find the location because it does not list a dir as it should. Does that sound correct. If so how do I fix it.
Any help would be great.
Matthew
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn more.
