I am trying to start Grass 7 svn on Ubuntu 13.10. I used the following command in terminal:
sudo apt-get update; sudo apt-get install grass70 grass70-gui
When i start Grass with ‘grass70’ in terminal the Grass ‘splash’ screen opens and then promptly crashes. Here is the error:
username@ServerName localhost:~$ grass70
WELCOME TO GRASS 7.0.svn
Have at your side all available GRASS tutorials
When working on your location, the following materials
are extremely useful:
- A topo map of your area
- Current catalog of available computer maps
- Check the GRASS webpages for feedback mailinglists and more:
http://grass.osgeo.org
http://www.grass-gis.org
Hit RETURN to continue
Starting GRASS GIS…
Fontconfig warning: “/etc/fonts/conf.d/50-user.conf”, line 14: reading configurations from ~/.fonts.conf is deprecated.
/ / __ / | / / / / __/ / /
/ / __/ // / /| | _ \ \ / / __ / / _
/ // / , / ___ |/ // / / // // / / /
_// |// |/// _///_/
Welcome to GRASS 7.0.svn
GRASS homepage: http://grass.osgeo.org
This version running through: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Launching GUI in the background, please wait…
GRASS 7.0.svn (dtm_location):~ > Fontconfig warning: “/etc/fonts/conf.d/50-user.conf”, line 14: reading configurations from ~/.fonts.conf is deprecated.
File “/usr/lib/grass70/etc/gui/wxpython/wxgui.py”, line 143, in
sys.exit(main())
File “/usr/lib/grass70/etc/gui/wxpython/wxgui.py”, line 136, in main
app = GMApp(workspaceFile)
File “/usr/lib/grass70/etc/gui/wxpython/wxgui.py”, line 50, in init
wx.App.init(self, False)
File “/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py”, line 7981, in init
self._BootstrapApp()
File “/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py”, line 7555, in _BootstrapApp
return core.PyApp__BootstrapApp(*args, **kwargs)
File “/usr/lib/grass70/etc/gui/wxpython/wxgui.py”, line 84, in OnInit
workspace = self.workspaceFile)
File “/usr/lib/grass70/etc/gui/wxpython/lmgr/frame.py”, line 110, in init
self._menuTreeBuilder = LayerManagerMenuData()
File “/usr/lib/grass70/etc/gui/wxpython/lmgr/menudata.py”, line 40, in init
MenuTreeModelBuilder.init(self, filename, expandAddons=expandAddons)
File “/usr/lib/grass70/etc/gui/wxpython/core/menutree.py”, line 69, in init
xmlTree = etree.parse(filename)
File “/usr/lib/python2.7/xml/etree/ElementTree.py”, line 1182, in parse
tree.parse(source, parser)
File “/usr/lib/python2.7/xml/etree/ElementTree.py”, line 657, in parse
self._root = parser.close()
File “/usr/lib/python2.7/xml/etree/ElementTree.py”, line 1654, in close
self._raiseerror(v)
File “/usr/lib/python2.7/xml/etree/ElementTree.py”, line 1506, in _raiseerror
raise err
xml.etree.ElementTree.ParseError: no element found: line 1, column 0
Paul Shapley
