[GRASS-user] Grass add-ons + i.atcorr
Dear all,
I’m working with Grass 6.2.2 on Linux CentOS 5.2, and want to use the imagery add-ons from the SVN repository. I managed to download them all using the ‘svn checkout…’ command, but when I try to install them with the ‘make MODULE_TOPDIR=/usr/lib/grass-6.2.2’ command, I always get the message ‘No targets specified and no makefile found.’ Hence, the commands in the makefiles of the add-ons won’t work since no MODULE_TOPDIR has been made. I know this might seem very basic, but I’m a complete beginer with little time to learn it all.
I’ve also just noticed that i.atcorr is not available in this version of Grass. Can it still be downloaded somewhere separately, and then just moved to the bin-directory of Grass?
Can anyone explain me (in simple terms, I’m new to Linux and Grass) how I can get these add-ons installed please?
Thanks!
Annekatrien
On Mon, 2008-11-10 at 12:38 +0100, Annekatrien Debien wrote:
Dear all,
I'm working with Grass 6.2.2 on Linux CentOS 5.2, and want to use the
all using the 'svn checkout...' command, but when I try to install
them with the 'make MODULE_TOPDIR=/usr/lib/grass-6.2.2' command, I
always get the message 'No targets specified and no makefile found.'
Hence, the commands in the makefiles of the add-ons won't work since
I'm a complete beginer with little time to learn it all.
I've also just noticed that i.atcorr is not available in this version
Can anyone explain me (in simple terms, I'm new to Linux and Grass)
Thanks!
Annekatrien
Dear Annekatrien,
the README file under ../grass-addons/ states:
The easiest way to compile GRASS Addons modules into your GRASS code
  is by setting MODULE_TOPDIR on the fly to tell 'make' where to
  find the GRASS source code:
    make MODULE_TOPDIR=$HOME/grass64/
So you need to point make to *source code* and not the installed binaries. That could be for example
mak MODULE_TOPDIR=/usr/local/src/grass64/
or wherever you store the source code.
Hope this helps.
Kind regards, Nikos
