[GRASS-user] GRASS and R question
I was wondering if I could get some brief feedback on exactly what are the
capabilities of the sp and spgrass6 -- say I'd like to use R to calculate
and NDVI image (I know mapcalc can do this fine, but I'm thinking of some
more complicated analyses that aren't easily performed in R and I figured if
I can figure out NDVI I can figure out the rest of them) -- Does sp,
spgrass6 and R itself provide both the data ingestion capabilities as well
as the necessary subsetting capabilities if my file is very large (e.g. Can
R do a per-pixel or per-line read/process/write routine, or will it attempt
to load an entire raster into memory)?
If R can deal with import of a multiband image and tiled processing, can
someone here perhaps post an example of how to accomplish the above task
(taking a 4 band large file, calculating NDVI and then writing out the NDVI
to disk) using R? Thanks!
--j
Jonathan A. Greenberg, PhD
NRC Research Associate
NASA Ames Research Center
MS 242-4
Moffett Field, CA 94035-1000
Office: 650-604-5896
Cell: 415-794-5043
AIM: jgrn307
MSN: jgrn307@hotmail.com
