I'm trying to build grass 6.4 rc1 from sources (using the tarball available) but I get this blocking error :
"libtoolize: cannot handle variables in AC_CONFIG_AUX_DIR"
Here is the complete log ->
http://pastebin.mandriva.com/5505
I've searched but the only part I've been able to understand so far is that it is somewhat linked to the configure file so there is the options I used :
--with-dbm-includes=%{_includedir}/gdbm/
--with-postgres-includes='%{_includedir}/postgresql %{_includedir}/postgresql/internal' --with-freetype --with-freetype-includes=%{_includedir}/freetype2 --with-motif --with-opengl-libs=%{_prefix}/X11R6/%{_lib} --with-motif-includes=%{_prefix}/X11R6/include --with-gdal --with-odbc --enable-largefile --with-ffmpeg
--with-curses --with-python --with-sqlite \
--with-cxx --with-proj-share=%{_datadir}/proj \
--with-nls --with-wxwidgets=%{_libdir}/wxPython/bin/wx-config
I'm using mandriva cooker/libtool 1.5.26/gcc 4.3.2
MORREALE JR
On Mon, Jan 5, 2009 at 11:00 PM, MORREALE Jean Roc
<jr.morreale@enoreth.net> wrote:
Please post the configure parameters/flags for inspection.
Apparently you are trying to create a RPM file? Please point
us to the SPEC file (note that the tarball contains
rpm/mandriva/grass*.spec
See also
http://svn.mandriva.com/cgi-bin/viewvc.cgi/packages/cooker/grass/current/
I am using Mandriva 2009.0 and have no problems.
But libtool isn't used/usable for GRASS, probably that's the
source of the problem. We need to know more specifically
what you plan to do.
Best
Here is my spec file ->
http://pastebin.mandriva.com/5551
It is based on the latest available on mandriva's contrib, I've not done much modifications except cleaning the rust and add the correct dependencies for the new gui. The spec file in the tarball you mentioned is an older version.
I want to submit a newer grass' package since I need it to submit qgis 1.0 and also because the actual one on cooker's svn is nearly one year old, conflicts over libavcodec due to wrong include's path, etc. The libtool thingy is set to be used by default in mandriva's rpmbuild.
On Tue, Jan 6, 2009 at 7:05 PM, MORREALE Jean Roc
I have updated it a bit but can now reproduce the problem.
It is a specialty when building RPMs.
version.
Older version yes, but with updates to 2009.x. I have updated that
again (new URLs) and also updated yours (will send offlist).
Excellent.
Right and an addition in GRASS 6.4.x causes the trouble. I have opened
a ticket for that:
http://trac.osgeo.org/grass/ticket/424
Feel free to add yourself in copy to watch it.
grass-user mailing list
grass-user@lists.osgeo.org
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
Found a workaround: replace
%configure
with
./configure
and libtoolize is no longer used.
Two fixes are necessary, then it compiles (running here now).
I'll send you the SPEC file.
%configure
with
./configure
Thank you for the tips !
yes but actually in cooker you can't even install it because of a dependency's conflict so a new grass rpm is really needed here.
Thanks again
