[GRASS-user] GRASS can't fetch interface description for Python script
Hi there,
I'm having a lot of trouble starting this script in GRASS. As I'm more than
a newbie in programming, this is probably some really basic mistake, but my
other scripts all work consistently in GRASS and I've been working on this
for quite a while with no success, so here goes :slight_smile:
I quickly put together a script, copied it into /opt/grass/scripts, and when
I try to call it from within GRASS it returns the following error:
  File "/opt/grass/etc/wxpython/gui_modules/prompt.py", line
1067, in OnKeyPressed
self.parent.RunCmd(cmd)
  File "/opt/grass/etc/wxpython/gui_modules/goutput.py",
line 516, in RunCmd
task = menuform.GUI().ParseInterface(command)
  File "/opt/grass/etc/wxpython/gui_modules/menuform.py",
line 2020, in ParseInterface
tree = etree.fromstring(getInterfaceDescription(cmd[0]))
line 1970, in getInterfaceDescription
"Details: %s") % (cmd, e.value)
AttributeError
'exceptions.OSError' object has no attribute 'value'
I'm not really able to find any differences between this script and another
script that works just fine. However, several scripts that I'd used about a
year ago don't work any more, even though the code's the same - very
mysterious. I'm using the most recent GRASS 6.4.1 from the OpenSUSE
geo-repository.
Any clues or tips would be greatly appreciated! Would enclose more
information, but I'm not sure what's exactly relevant and I don't want to
spam ya'll with my entire code. Thanks!
Daniel
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-can-t-fetch-interface-description-for-Python-script-tp6393688p6393688.html
...Yes, you can laugh at me...
I've been trying to solve this program for a week. The only problem was that
I hadn't made the script executable. Sorry!!! It works now :wink:
Now I have to go dunk my head in icewater...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-can-t-fetch-interface-description-for-Python-script-tp6393688p6393725.html
As I'm more than a newbie in programming, this is probably
some really basic mistake, but my other scripts all work
/opt/grass/scripts, and when I try to call it from within
Is /opt/grass/scripts set up in GRASS_ADDON_PATH, and
  export GRASS_ADDON_PATH=/opt/grass/scripts
set up in ~/.bashrc ?
(Scripts run in two passes, the first will start from the pwd,
but if that's not in the $PATH then the second g.parser pass
won't be able to find itself, and you get a not-very-helpful
error message.)
just a guess,
Hamish
Hi Hamisch,
thanks for the reply, but the problem was even more basic than that - I'd
simply forgotten to make the script executable. A simple mistake, but one
that I needed hours to recognize, probably due to programming for too long
without a break :wink:
Daniel
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-can-t-fetch-interface-description-for-Python-script-tp6393688p6411247.html
