I find some java code to call the grass commond,i am confusing with some parmeters:
- Define all environment variables needed by Grass
- @param gisBase
- Directory where GRASS lives.
- @param gisRcreate
- Define if an existing GISRC file as to be used.
- @param gisRc
- Name of .grassrc6 file. GISRCRC defines the system wide value
- while in a GRASS session.
- @param mapset
- Initial mapset directory which is a subdirectory of
- LOCATION_NAME
- @param location
- Initial location directory which is a subdirectory of GISDBASE
- @param gisDBase
- Initial database directory which should be a fully qualified
- path (eg /usr/local/share/grassdata).
- @param proj
- Projection code.
public void setEnv(String gisBase, String gisRcreate, String gisRc,
String mapset, String location, String gisDBase, String proj)
what is the difference between gisRcreate and the gisRc
