* Nikos Alexandris <nik@nikosalexandris.net> [2015-05-02 11:38:23 +0300]:
* Nikos Alexandris <nik@nikosalexandris.net> [2015-05-02 10:21:06 +0300]:
> * Jake Chila <jake.chila@gmail.com> [2015-05-01 11:33:01 -0300]:
> > hi all,
> > So I am trying to run i.atcorr but every time I run it, the whole program
> > goes unresponsive and crashes. Has anyone experienced this before? Is there
> > any way I can fix it?
> > One thing that might be causing it is my parameters text file. I'm not
> > totally sure I understand what all the fields are but here is an example of
> > the parameter files I have created. This one is for the second band of a
> > landsat 5 TM scene over central British Columbia
> > 7
> > 8 15 18.49 -116.027755 50.267045
> > 2
> > 0
> > 0
> > 0
> > -1000
> > 26
> Hi Jake.
> Please have a close look in the manual. As well, here:
> <http://grasswiki.osgeo.org/wiki/Atmospheric_correction#Atmospheric_correction>\.
> If Landsat is your sensor to work with, here is a script around
> i.atcorr: <https://github.com/NikosAlexandris/i.landsat.atcorr>\. I
> haven't used this in Windows though, and to upload it into grass-addons
> I need to test it more.
Unfortunately, something is broken currently and I have no time to check
it :-(.
Jake, if you read Python, you could, however, make use of the Parameters python class
defined in
<https://github.com/NikosAlexandris/i.landsat.atcorr/blob/master/parameters.py>\.
I will create a text file with the requested parameters suitable for i.atcorr.
An example inside python:
# import class
from parameters import Parameters
# check it out with help()
# help(Parameters)
# create object with desired six s parameters for i.atcorr
ssp = Parameters(geo=8,
mon=11, day=8, gmt='23:42',
lon=22.2, lat=33.3,
atm=2, aer=1, vis=10, aod=None,
xps=-200, xpp=-1000,
bnd=26)
# what is it like?
print ssp
Parameters for the 6S atmospheric correction model:
8 # Geometrical conditions
11 8 23.70 22.200000 33.300000 # Month Day GMT Center Longitude Latitude [DD]
2 # Atmospheric model [index]
1 # Aerosols model [index]
10.0 # Visibility [km]
-200.0 # Mean Target Altitude [negative km]
-1000 # Sensor Altitude rel. to xps [negative km] or SatelliteBorn [-1000]
26 # Satellite Band Number [index]
# export it to an ascii file
p6s.export_ascii("ssp_example.txt")
# what is inside the exported file?
cat p6s_example.txt
Nikos
