Dear all,
I have just installed GRASS cvs on linux centos4. The configure seems
ok, I have installed gdal from source and I got "gdal support" ok after the configure. However, when starting grass, after a new location was created the main window appears for a second, then crashes and I get:
"child process exited abnormally"
-> If I try d.m command I get:
Error in startup script: ps.map: error while loading shared libraries:
libgdal.so.1: cannot open shared object file: No such file or directory
while executing
"exec ps.map -p"
(procedure "DmPrint::init" line 14)
invoked from within
"DmPrint::init"
(procedure "main" line 34)
invoked from within
"main $argc $argv"
(file "/usr/local/grass-6.3.cvs/etc/dm/d.m.tcl"
line 1637)
-> The command "d.rast" and "d.mon x0" work fine, while "d.vect" gives:
GRASS 6.3.cvs (UTM_ED50_33):/usr/local/cvs/grass6 > d.vect
d.vect: error while loading shared libraries: libgdal.so.1: cannot open
I saw some thread about this but I could not sort it out
Can anyone help?
crashes and I get:
Add the directory where libgdal.so.1 resides to the file
/etc/ld.so.conf, then run ldconfig.
Hi Glynn,
many thanks for your very quick reply, that worked fine.
cheers
Francesco
> crashes and I get:
crashes and I get:
make sure GDAL is installed correctly and /usr/local/lib (or where gdal
libs are installed) is listed in /etc/ld.so.conf. Run /sbin/ldconfig
after editing /etc/ld.so.conf.
or maybe you need to make a symlink to "libgdal.so.1" if it is named
like libgdal1.3.1.so.1?
ln -s /usr/lib/libgdal1.3.1.so.1 /usr/lib/libgdal.so.1
