[GRASS-user] Grass e QGIS on netbook with ubuntu 10.4 remix
have a look to #2721 in qgis 's trac
Jean Roc
Le mar 22/06/10 08:15, "Maris Nartiss" maris.gis@gmail.com a écrit:
Hello,
if You use GRASS from within QGIS, You should contact QGIS developers,
as GRASS support in QGIS is developed by QGIS developers and not
GRASS'ers.
I have not used Ubuntu, still in KDE with KWin I can drag around
windows by holding Alt key. Probably helps.
Maris.
2010/6/21, Edmondo Elisei <edmo
ndo.elisei@gmail.com>:
I'm using qgis 1.4 as plugin in GRASS 6.4 on a eeepc
1008 netbook with
ubuntu 10.4 REMIX.
> The properties-layer panel aren't resizable and i'm
not able to view the
bottom command (as the "Ok" botton).
> I've tried change the monitor resolution with the
same result.
Some suggestion?
> thanks and regards (... I'm sorry for my
english)
> E.
grass-user mailing list
gr
ass-user@lists.osgeo.org
