[GRASS-user] GRASS Environment Variables
Hi?
I have been trying to call GRASS modules using python outside GRASS session, I am coding in PyCharm however, I am having a problem importing grass scripts and the solution being provided is setting GRASS environment variables. How do I go about that so to import GRASS modules in Pycharm?
Kind Regards,
Joseph Kariuki
Geospatial Engineer | GIS / Web Developer
Hello Joseph,
There is a solution, but it is not straight forward:
https://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
Another option is to start your editor from the GRASS command line.
Laurent
2017-04-04 9:12 GMT-05:00 Joseph Kariuki <joehene@gmail.com>:
Hi?
Kind Regards,
Joseph Kariuki
grass-user mailing list
grass-user@lists.osgeo.org
Hello Joseph,
This is the way I work with grass from python:
#!/usr/bin/env python
-- coding: utf-8 --
import os
import sys
#1. Define function
def conectar(location,mapset):
path to the GRASS GIS launch script
grass7bin = ‘/usr/bin/grass72’
Set GISDBASE environment variable
gisdb = “/media/andres/Andres/TesisGrass”
os.environ[‘GISDBASE’] = gisdb
query GRASS 7 itself for its GISBASE
gisbase = “/usr/lib/grass72”
os.environ[‘GISBASE’] = gisbase
define GRASS-Python environment
gpydir = “/usr/lib/grass72/etc/python”
sys.path.append(gpydir)
import GRASS Python bindings
import grass.script.setup as gsetup
############ launch session
gsetup.init(gisbase, gisdb, location, mapset)
#2. Now you can connect with your projects
location = “your location”
mapset = “your mapset”
#3. Call function (examples)
gscript.run_command(‘g.region’, n=float(n), s=float(s), e=float(e), w=float(w), ewres=float(res), nsres=float(res))
gscript.run_command(“r.in.gdal”, input=“/home/…/image.tif”, flags=‘e’,output = “image”)
2017-04-04 11:12 GMT-03:00 Joseph Kariuki <joehene@gmail.com>:
Hi?
Kind Regards,
Joseph Kariuki
Hi Andres, I have run the code in pycharm but still raises an error
/usr/bin/python2.7 /home/hempire/PycharmProjects/GRASS/ingrass.py
File “/home/hempire/PycharmProjects/GRASS/ingrass.py”, line 43, in
NameError: name ‘gscript’ is not defined
Process finished with exit code 1
However on terminal it executes with no errors. I will stick to using terminal. PyCharm is limiting.
On Wed, Apr 5, 2017 at 2:12 AM, Andres Solarte <e.andres.solartec@gmail.com> wrote:
Hello Joseph,
-- coding: utf-8 --
import os
import sys
#1. Define function
Kind Regards,
Joseph Kariuki
Hi?
Kind Regards,
Joseph Kariuki
Hi Joseph,
You just have to import the module:
import grass.script as gscript
See also:
https://grass.osgeo.org/grass72/manuals/libpython/script_intro.html
Stefan
Kind Regards,
Joseph Kariuki
Hello Joseph,
-- coding: utf-8 --
import os
import sys
#1. Define function
Hi?
Kind Regards,
Joseph Kariuki
Hello Joseph,
my fault,
add this line after #3.
now it should works!
remember set your coordinates and resolution (example)
res = 0.008626704385179
n = 14.
s = -2.
w = -76
e = -65
Regards
2017-04-05 9:43 GMT-03:00 Joseph Kariuki <joehene@gmail.com>:
Kind Regards,
Joseph Kariuki
Hello Joseph,
-- coding: utf-8 --
import os
import sys
#1. Define function
Hi?
Kind Regards,
Joseph Kariuki
