[GRASS-user] grass gis 6.4.4 i.atcorr exe problem
hello all,
i have compiled grass 6.4.4 on windows. i.atcorr is th module required
for us. i have to customize it for IRS liss4 sensor. so for landsat
data i have tested by giving the parameters to the exe created after
compilation. but i am not sure about the parameters and whether it is
working properly. i have set environment variables gisbase and gisrc
also. but it was mentioning "no module found named grass.script" can
any one tell me how to correct arguments to pass i.atcorr..
parameters given are: i.atcorr -r -a -o lsat7_2002_40_rad
ialt=elevation icnd=icnd_lsat4.txt oimg=lsat7_2002_40_atcorr as shown
in the link grass.osgeo.org/grass65/manuals/i.atcorr.html.
Regards
kams
On Thu, Oct 30, 2014 at 6:32 AM, kameswari devi <kams.devi@gmail.com> wrote:
hello all,
If you have the filter functions for the IRS liss4 sensor we can add
that to i.atcorr.
so for landsat
Maybe this page can help you:
http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
