[GRASS-user] Grass-GIS 6.4 font bug in OSX
I've just install 6.4 under OSX 10.5.8, and have run into a problem.
Reproduced in Spearfish:
d.vect bugsites - OK
d.vect bugsites display=attr attrcol=str1 - OK
d.vect bugsites display=attr attrcol=str1 font='Arial Italic'
produces this error, repeated many times:
The process has forked and you cannot use this CoreFoundation functionality safely. You MUST exec().
Break on __THE_PROCESS_HAS_FORKED_AND_YOU_CANNOT_USE_THIS_COREFOUNDATION_FUNCTIONALITY___YOU_MUST_EXEC__() to debug.
Then the X monitor window closes.
Any ideas?
Richard
On Sun, Sep 26, 2010 at 11:12 PM, Richard Chirgwin
<rchirgwin@ozemail.com.au> wrote:
Break on
to debug.
Any ideas?
See
http://trac.osgeo.org/grass/ticket/377
http://lists.osgeo.org/pipermail/grass-user/2009-April/050038.html
and
http://developer.apple.com/mac/library/technotes/tn2005/tn2083.html#SECDAEMONVSFRAMEWORKS
Break on
to debug.
Any ideas?
See
and
That's depressing: am I right in assuming it's been observed but there isn't a fix?
Richard
Well, it looks like it's coming from FreeType. There was this problem with Freetype once, but I thought it was fixed. Strangely, it doesn't affect dfonts, just TT and OTF fonts. Snow Leopard is OK.
I can look into my FreeType framework to see if I messed up something in a recent update.
Break on
to debug.
Any ideas?
See
and
Richard
grass-user mailing list
grass-user@lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
  Fingers crossed!
One of the problems Markus cited as associated with database selection, which I have *not* experienced. This is strictly fonts. Thanks in advance for your efforts & assistance!
Richard
Break on
to debug.
Any ideas?
See
and
Richard
William Kyngesburye<kyngchaos*at*kyngchaos*dot*com>
Here's the deal. (The matter has come up before, but real no solutions have been offered.)
The error means what it says. It comes from FreeType when the old-mac-fonts options is enabled, and there is nothing that FreeType can do to "fix" it, because old-mac-fonts means it needs to use Core Foundation. The real solution is that programmers using FreeType on OS X 10.5 needs to do as the error suggests, exec() after fork(). This forum topic at Apple describes it concisely:
http://discussions.apple.com/message.jspa?messageID=7875639
The quick solution is to build FreeType without old-mac-fonts. But there are many with an investment in old Resource-fork based fonts (mainly PostScript) and this is not a good solution ($$ to upgrade to OTF).
I don't know why Snow Leopard doesn't have the problem. Maybe Apple saw that so many had problems with this and reverted, or at least dropped the error (they probably still recommend fork + exec).
I don't know what to do to fix this in GRASS, but there is a list thread referenced in the bug report Markus mentioned that has suggestions from Glynn.
The database problem I think is just an extension of this - that is, it didn't appear until the database connection was used for d.vect labels and the error output was hidden in the X11 monitor process, or was missed by the person who reported the bug.
On Sep 27, 2010, at 5:20 PM, Richard Chirgwin wrote:
Fingers crossed!
Richard
Break on
to debug.
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
