I just tried to install this. I had a very recent 7.0 of yours installed.
When I run the installer, it makes it through most of the steps. Then,
near the end, it says, validating and finally brings up an error.
Here is what shows in the box:
There were errors with the installation. You may want to try (then the
message is cut off).
The installation failed.
The installer encountered n error that caused the installation to tail.
Contact the software manufacturer for assistance.
The install log is below:
Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: LSExceptions
[0x6080000b9380] loaded
Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: @(#)PROGRAM:Install
PROJECT:Install-846
Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: @(#)PROGRAM:Installer
PROJECT:Installer-721
Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Hardware: MacBookPro9,1
@ 2.60 GHz (x 8), 8192 MB RAM
Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Running OS Build: Mac
OS X 10.9.2 (13C64)
Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Env:
PATH=/usr/bin:/bin:/usr/sbin:/sbin
TMPDIR=/var/folders/s4/0j3cshj161126ygbpbzsdkmd4h24dl/T/
Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Env: SHELL=/bin/bash
HOME=/Users/adershowitz
Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Env: USER=adershowitz
Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Env: LOGNAME=adershowitz
GPG_AGENT_INFO=/Users/adershowitz/.gnupg/S.gpg-agent:634:1
SSH_AUTH_SOCK=/tmp/launch-cRtteu/Listeners
Apple_PubSub_Socket_Render=/tmp/launch-YoZwJc/Render
DISPLAY=/tmp/launch-UzS5ph/org.macosforge.xquartz:0
DBUS_LAUNCHD_SESSION_BUS_SOCKET=/tmp/launch-LKGofO/unix_domain_listener
__CF_USER_TEXT_ENCODING=0x490111B3:0:0
Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Env: __CHECKFIX1436934=1
Apr 7 09:39:02 adershowitzMBP15 Installer[57796]: GRASS-7.0 Installation
Log
Apr 7 09:39:02 adershowitzMBP15 Installer[57796]: Opened from:
/Users/adershowitz/Downloads/Navigate etc/GRASS-7.0beta1.pkg
Apr 7 09:39:03 adershowitzMBP15 Installer[57796]: Referenced component
packages (1) trustLevel=100
Apr 7 09:39:13 adershowitzMBP15 Installer[57796]: LSExceptions
[0x6080000b9380] unloaded
Apr 7 09:39:34 adershowitzMBP15 Installer[57796]:
InstallerStatusNotifications plugin loaded
Apr 7 09:39:42 adershowitzMBP15 runner[57801]: Administrator
authorization granted.
Apr 7 09:39:42 adershowitzMBP15 Installer[57796]:
Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: User picked Standard
Install
Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Choices selected for
installation:
Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Upgrade: "GRASS-7.0"
Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: GRASS-7.0beta1.pkg :
org.osgeo.grass7_0 : 7.0.140403.7.0
Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: It took 0.00 seconds to
summarize the package selections.
Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: -[IFPKGDerivedDocument
sortedPackageLocations]: result = (
"file://localhost"
-[IFDInstallController(Private) _buildInstallPlan]: location =
file://localhost
file://localhost/Users/adershowitz/Downloads/Navigate%20etc/GRASS-7.0beta1.
pkg
Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Set authorization level
to root for session
Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Will use PK session
Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Starting installation:
Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Configuring volume
"Macintosh HD"
Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: Preparing disk for
local booted install.
Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: Free space on
"Macintosh HD": 121.37 GB (121369862144 bytes).
Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: Create temporary
directory
"/var/folders/s4/0j3cshj161126ygbpbzsdkmd4h24dl/T//Install.577965qM2wZ"
Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: IFPKInstallElement (1
packages)
Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: Using authorization
level of root for IFPKInstallElement
Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: Adding
client PKInstallDaemonClient pid=57796, uid=1224806835
(/System/Library/CoreServices/Installer.app/Contents/MacOS/Installer)
Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: PackageKit: Enqueuing
install with boosting
Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: ----- Begin
install -----
request=PKInstallRequest <1 packages, destination=/>
Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: packages=(
"PKJaguarPackage
<file://localhost/Users/adershowitz/Downloads/Navigate%20etc/GRASS-7.0beta1
.pkg>"
Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: Will do
receipt-based obsoleting for package identifier org.osgeo.grass7_0 (prefix
path=Applications/GRASS)
Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: Extracting
pkg
(destination=/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/PKInstallSand
boxManager/E4657E3B-0CFE-48D5-B3F5-BBA5ABA8E7A7.activeSandbox/Root/Applicat
ions/GRASS, uid=0)
Apr 7 09:40:14 adershowitzMBP15 installd[48393]: PackageKit: prevent user
idle system sleep
Apr 7 09:40:14 adershowitzMBP15 installd[48393]: PackageKit: suspending
backupd
Apr 7 09:40:15 adershowitzMBP15 install_monitor[57819]: Temporarily
excluding: /Applications, /Library, /System, /bin, /private, /sbin, /usr
Apr 7 09:40:20 adershowitzMBP15 installd[48393]: PackageKit: Using
trashcan path
/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/PKInstallSandboxTrash/E465
7E3B-0CFE-48D5-B3F5-BBA5ABA8E7A7.sandboxTrash for sandbox
/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/PKInstallSandboxManager/E4
Apr 7 09:40:20 adershowitzMBP15 installd[48393]: PackageKit: Shoving
657E3B-0CFE-48D5-B3F5-BBA5ABA8E7A7.activeSandbox/Root (1 items) to /
Apr 7 09:40:26 adershowitzMBP15 installd[48393]: PackageKit: Executing
script "./postflight" in /Users/adershowitz/Downloads/Navigate
etc/GRASS-7.0beta1.pkg/Contents/Resources
Apr 7 09:40:26 adershowitzMBP15 installd[48393]: PackageKit: *** launch
path not accessible
Apr 7 09:40:26 adershowitzMBP15 install_monitor[57819]: Re-included:
Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: releasing
backupd
Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: allow user
idle system sleep
Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: Install
Failed: Error Domain=PKInstallErrorDomain Code=112 "An error occurred
while running scripts from the package ³GRASS-7.0beta1.pkg²."
UserInfo=0x7fcf8b60a540 {NSFilePath=./postflight,
NSURL=file://localhost/Users/adershowitz/Downloads/Navigate%20etc/GRASS-7.0
beta1.pkg, PKInstallPackageIdentifier=org.osgeo.grass7_0,
NSLocalizedDescription=An error occurred while running scripts from the
package ³GRASS-7.0beta1.pkg².} {
NSFilePath = "./postflight";
NSLocalizedDescription = "An error occurred while running scripts
from the package \U201cGRASS-7.0beta1.pkg\U201d.";
NSURL =
"file://localhost/Users/adershowitz/Downloads/Navigate%20etc/GRASS-7.0beta1
.pkg";
PKInstallPackageIdentifier = "org.osgeo.grass7_0";
Apr 7 09:40:27 adershowitzMBP15 Installer[57796]:
install:didFailWithError:Error Domain=PKInstallErrorDomain Code=112 "An
error occurred while running scripts from the package
³GRASS-7.0beta1.pkg²." UserInfo=0x6100000eb400 {NSFilePath=./postflight,
Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: Running idle
tasks
Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: Removing
Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: Done with
sandbox removals
Apr 7 09:40:27 adershowitzMBP15 Installer[57796]: Install failed: The
Installer encountered an error that caused the installation to fail.
Apr 7 09:40:27 adershowitzMBP15 Installer[57796]: IFDInstallController
2E30 state = 8
Apr 7 09:40:27 adershowitzMBP15 Installer[57796]: Displaying 'Install
Failed' UI.
Apr 7 09:40:27 adershowitzMBP15 Installer[57796]: 'Install Failed' UI
displayed message:'The Installer encountered an error that caused the
installation to fail. Contact the software manufacturer for assistance.'.
Thanks, and any thoughts or suggestions are appreciated.
-- Adam
On 4/3/14, 7:30 PM, "Michael Barton" <Michael.Barton@asu.edu> wrote:
I compiled the new GRASS 7 beta1 from the current release branch and
posted it to the http://grassmac.wikidot.com web site. In order to make
this available as soon as possible, I have had to compile it without LAS
tools and without gettext internationalization support. If you install
this,IT WILL OVERWRITE YOUR EXISTING GRASS 7 INSTALLATION unless you move
GRASS 7 out of the /Applications/Grass folder.Michael
______________________________
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
Tempe, AZ 85287-2402
USAvoice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbartonOn Mar 30, 2014, at 1:37 PM, Markus Neteler <neteler@osgeo.org> wrote:
Dear Packagers,
(pls fwd if I forgot to cc a packager)after almost 6 years of development, a first 7.0.0beta1 is out:
http://grass.osgeo.org/grass70/source/grass-7.0.0beta1.tar.gz
http://grass.osgeo.org/grass70/source/grass-7.0.0beta1.md5sumCould you please provide an updated installer for your distro?
(note: winGRASS standalone is already there)I'm still completing the announcement at
http://trac.osgeo.org/grass/wiki/Release/7.0.0beta-Newsand other places (feel free to improve the pages).
on behalf of all GRASS GIS users,
thanks
MarkusPS: known potential packaging issue with patch suggestion:
http://trac.osgeo.org/grass/ticket/1839--
http://courses.neteler.org/
http://gis.cri.fmach.it/neteler/_______________________________________________
grass-user mailing list
grass-user@lists.osgeo.org
