Being unable to import matplotlib in my python scripts in the GRASS GIS environment (and not able to find binaries for matplotlib 1.2.0 for 32 bit python 2.6, which is needed for the wxgui) - I took the following workaround steps, perhaps they may be useful to someone or save some time. Or, even better, perhaps someone knows how to access matplotlib from the bundled python.
Downloaded python 2.7 and matplotlib 1.2.0 (as well as numpy and ipython), following recommendations at
http://matplotlib.org/faq/installing_faq.html#os-x-notes
I now have two versions of python on my system (Mac OS X Version 10.7.5). The new installation (2.7), and version 2.6 bundled with Michael Barton's GRASS GIS 7.0 binaries (William Kingesburye's frameworks).
In my .bash_profile I have these GRASS and python related lines:
export PATH=$PATH:/usr/local/mysql/bin:/usr/bin/python:/Applications/GRASS-7.0.app/Contents/MacOS/scripts
export PATH=/Library/Frameworks/GDAL.framework/Programs:$PATH
export PATH=/Library/Frameworks/Python.framework/Versions/Current/bin:${PATH}
The following python script file was saved to my home directory:
/Users/joneiriksson/je_01.py
#!/usr/bin/env python-32
import sys
from grass.script import core as grass
from grass.script import db as grass
from array import array
import matplotlib.pyplot as plt
def get_convergence():
returned_conv_angle = grass.read_command('g.region', flags = 'n')
conv_angle = grass.parse_key_val(returned_conv_angle)
return str(conv_angle)
def plot_points_graph():
xy =
zero = 0.0
xy = [[zero for i in range(2)] for j in range(6)]
ix,target = 0,5
while ix <= target:
xy[ix][0] = ix
xy[ix][1] = ix
ix = ix + 1
print ix
print xy
plt.plot(xy, 'ro')
plt.axis([-1, 6, -1, 6])
plt.grid(True)
plt.show()
def main():
c_angle_string = get_convergence()
print 'convergence angle string = ',c_angle_string
plot_points_graph()
return 0
# this "if" condition instructs execution of code contained in this script,
# *only* if the script is being executed directly
if __name__ == "__main__": # this allows the script to be used as a module in other scripts or as a standalone script
options, flags = grass.parser() #
sys.exit(main()) #
Note the alias in the first line of the script:
- instead of the normally used
- this notation activates python 2.7 instead of the bundled python 2.6
This enables me to call matplotlib functions from my script, which is activated in the GRASS GIS Terminal window by the command:
GRASS 7.0.svn (je_location):~ >je_01.py
Other GRASS related python scripts reside in:
/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/scripts/
and work as before, using python 2.6 (#!/usr/bin/env python), compatible with the wxgui
Jon
