[GRASS-user] GRASS GIS 7.8.5 v.distance
I am trying to use the v.distance function in GRASS GIS 7.8.5, however, it won’t accept ‘from’ as a parameter as it’s a python keyword (I think). When I use ‘FROM’ I get an error saying:
WARNING: Illegal filename <FROM=buildings>. Character <=> not allowed.
ERROR: Vector map <FROM=buildings> not found
This is the code I’m trying to run:
gs.run_command('v.distance',
    FROM = 'buildings',
    to = 'mappedStreams',
    upload = 'to_attr',
    column = 'stream_id',
    to_column = 'OBJECTID',
    output = 'distanceLines',
    overwrite = True)
Any help would be greatly appreciated.
Thanks!
Hi Kelsey,
Try: "from_"
So,
    from_ = 'buildings',
The problem is indeed that from is a keyword...
Stefan
-----Original Message-----
From: grass-user <grass-user-bounces@lists.osgeo.org> On Behalf Of Kelsey Wong
Sent: torsdag 13. mai 2021 21:32
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] GRASS GIS 7.8.5 v.distance
I am trying to use the v.distance function in GRASS GIS 7.8.5, however, it won't accept 'from' as a parameter as it's a python keyword (I think). When I use 'FROM' I get an error saying:
This is the code I'm trying to run:
    FROM = 'buildings',
    upload = 'to_attr',
    overwrite = True)
Thanks!
grass-user mailing list
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgrass-user&amp;data=04|01||8d24cded0189434d8cc708d91646e043|6cef373021314901831055b3abf02c73|0|0|637565316357978059|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=Wi6V%2FnzJQvTKzyUf0oK6q18d0MOMI%2FPOrLbNms2BfZQ%3D&amp;reserved=0
Hi Stefan,
Thank you so much - that solved my entire problem!
Kelsey
On May 13, 2021, at 1:04 PM, Stefan Blumentrath <Stefan.Blumentrath@nina.no> wrote:
Hi Kelsey,
Try: “from_”
So,
gs.run_command(‘v.distance’,
from_ = ‘buildings’,
to = ‘mappedStreams’,
The problem is indeed that from is a keyword…
Stefan
FROM = ‘buildings’,
upload = ‘to_attr’,
column = ‘stream_id’,
to_column = ‘OBJECTID’,
output = ‘distanceLines’,
overwrite = True)
Thanks!
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgrass-user&data=04%7C01%7C%7C8d24cded0189434d8cc708d91646e043%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637565316357978059%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=Wi6V%2FnzJQvTKzyUf0oK6q18d0MOMI%2FPOrLbNms2BfZQ%3D&reserved=0
