[GRASS-user] GRASS GIS i.atcorr for aerial data
Hello
i have customized i.atcorr module for satellite sensors of altitude 800kms.It is working properly.i want to find out whether Grass GIS i.atcorr module be customized for Aerial sensor?
Attempted for Aerial sensor which has altitude of 13km but module failed.if the satellite altitude is above 100 km in the icnd file, module is working also if the it is given as positive number also working.If it is below 100km not working by saying"wavelength below 0.25nm." Is there any limitation for the satellite altitude in icnd file.may i know whether i.atcorr supports to Aerial data or not? is anybody used AVIRIS for grass atmospheric correction.
ยทยทยท
Regards
kameswari devi P
Scientist-C
On Fri, May 6, 2016 at 7:05 AM, kameswari devi <kams.devi@gmail.com> wrote:
Hello
Since it has been developed for satellites I have some doubts.
You may want to inspect the source code for this:
https://trac.osgeo.org/grass/browser/grass/trunk/imagery/i.atcorr
correction.
I used it for Landsat, LISS etc so far.
Markus Neteler
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
