[GRASS-user] GRASS GIS Web UI
Here is GRASS GIS Web UI connected with OpenLayers widget
http://lsi.iiit.ac.in/lsi/wgrass
The app is under development and is released for initial testing. For testing purpose we fix a lat/lont location and concentrate on vector data
Location Info:
extent -180,-90,180,90
mapset PERMANENT
you can import any grass vector data using v.in.ogr and display it in OL using d.vect
For Listed GRASS modules:
  1. Type on search box on top for list and select a module and hit enter or click search
  2. you will get a menuForm of the selected GRASS module.
  3. Fill all the attributes and click run to execute the grass module.
You can also run any grass command v.* or r.* using this webUI which is unlisted
please test it…
Any comments, suggestions, BUGS are always welcomed…
Thanks && Regards
Rashad
On Fri, Aug 5, 2011 at 9:46 PM, Mohammed Rashad <mohammedrashadkm@gmail.com> wrote:
in case this link is not working please use this
http://lsi.iiit.ac.in:9090/wgrass
Location Info:
mapset PERMANENT
please test it…
Thanks && Regards
Rashad
Thanks && Regards
Rashad
Does it use WPS, or some properitary protocol?
Jachym
2011/8/10 Mohammed Rashad <mohammedrashadkm@gmail.com>:
wrote:
Location Info:
mapset PERMANENT
using d.vect
click search
unlisted
please test it....
Any comments, suggestions, BUGS are always welcomed..
Thanks && Regards
Rashad
Thanks && Regards
Rashad
grass-user mailing list
grass-user@lists.osgeo.org
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
