[GRASS-user] GRASS GIS
Dear Grass users
Software: windows native Grass 63 and spearfish 60 data
Problem: facing problem in “v.in.ogr” command.
Description:
Successfully started GRASS GIS and spearfish data loaded.
First opened File → Import → Vector map → Multiple formats using OGR.
v.in.ogr window appears
First Parameter needed is “path to the shape file (OGR data source
name)”
Suppose my shape file data is in location “C:\world_factbk”
So I have given the path C:\world_factbk in OGR Datasource name box.
name of the vector map to be created (Name of output vector map): worlds
name of the file shp to be imported (OGR layer name), without
extension:
world_factbk
Override projection is check box is clicked.
RUN is clicked
Output in GIS.m window:
ERROR: Unable to open data source <C:/world_factbk/world_factbk>
I wander what will be its solution
Sincerely yours
Md.Zahid Parvez
Hello,
at first - when reporting a problem, please include full command with
all of it's parameters. Use copy/paste to transfer also all typos You
may have.
Second - double check that there is a file named
C:/world_factbk/world_factbk and You can read it. I suppose You have
read manual where shapefile import example is given. And if You use
projection override option, are Your data in same projection as
current location?
Documentation is Your friend.
Maris.
2008/9/28 Zahid Parvez <grassgisbangladesh@gmail.com>:
Dear Grass users
Software: windows *native Grass 63* and *spearfish 60* data
Problem: facing problem in "*v.in.ogr*" command.
Description:
First opened File -> Import -> Vector map -> Multiple formats using OGR.
First Parameter needed is "path to the shape file (OGR data source
name)"
   Suppose my shape file data is in location "C:\world_factbk"
extension:
world_factbk
RUN is clicked
Sincerely yours
Md.Zahid Parvez
grass-user mailing list
grass-user@lists.osgeo.org
