Thank you for your reply. Sorry i'm newbie with grass
1/ I downloaded grass 7 beta on my windows 7. I installed the v.isochrones
from addons.
But how to use this new extension ? is it possible to use an graphical
interface (gui) or i have to use the prompt command?
So according to you, it's more appropriate to use v.isochrones than
v.net.iso ?
2/ Regarding my area of study : the region of Paris.
from addons.
Just type v.isochrones in the command console of the GUI (or in the terminal) and the graphical interface of the command will pop up.
If you want to include extensions in your menus, or just customise the existing menus, you can use the toolboxes [1].
v.net.iso ?
v.net.iso gives you isochrones along networks, so the different segments of the network will be categorised according to the isochrone they belong to. See the examples in the man page for illustration: [2] or a video (also illustrating the new interactive network tool) [3]
v.isochrones creates polygons across all the space of the current working region, i.e. it estimates travel time also for places that are not on the network. The man page does not seem to be online currently, but you can see a video based on a development version for illustration [4].
OpenStreetMap is of very good quality in Paris, so you can use that.
Thank you very much. The v.isochrones seems to require in input a vector
network (roads) with a speed attributes column. I have just checked my
openstreetmap roads vector layer. And this column is not fully completed,
data are lacking for many routes. How can I do? According to you, before
applying v.isochrones, should I do anything on the input data (editing about
attributes or/and geometry/topology) ?
v.isochrones does not require a topologically clean network. If possible errors (e.g. non-closures) are below resolution size, they should not even make any difference.
As mentioned privately, I actually haven't tested the module with missing speed attribute data, so I don't know the consequences and don't have time currently to look into that.
thank you again for your last usefull messages. Regarding my driving
isochrone works. Last time (December 2014), when i executed the v.isochrones
process, an error message appeared due to running of memory.
For remind, i 'm working on windows 7 with grass 7.0. The vector network
comes from OSM data ('roads cover). This is a big road network (490 lines
objects!!) with of course the usefull field for speed profile. My area of
interest is componed by the two french admnistrative regions (Ile de France
and Picardie).
I have only one starting point. The projection is lambert 93.
So i have just tried a new test. I changed the resolution (nsres : 100/
ewres :99.9) just to ensure, for the time being, that the process works
well. But i have a new error message which would seem to have no link with
memory problem this time. I paste below the error message :
and Picardie).
I imagine you are lacking a few zeroes here. 490 lines is not a big network
File "C:\Users\laurent\AppData\Roaming\GRASS7\addons/scrip
ts/v.isochrones.py", line 158, in main
null_value = resolution / (float(offroad_speed) * 1000 /
3600)
ZeroDivisionError: float division by zero
Yes, I forgot to foresee the case where the user wants an offroad speed of 0. For now, could you just put this to a very low value > 0 ?
Actually, what you seem to want is more like what I started to implement in the alternative method, i.e. v.net.iso + r.grow.distance in which every pixel is just assigned to the travel time of the closest network segment, within a user-defined distance threshold to the network (thus potentially allowing empty areas not covered by isochrones).
I'm realy sorry to disturb you. But isochrony maps is really important my my
project.
I'll try to find some time soon to update the module with the second method.
