[GRASS-user] GRASS, import shapefiles with v.in.ogr, duplicate column name problem
Hi list,
I just encountered a problem, when trying to import a shapefile with a big
dbf-table that contains a duplicate field name.
I could not import this file into GRASS because of this and need to modify the
dbf-table first.
However, as the table is that large, I cannot open it in OpenOffice (too many
rows. The file is imported only partially) - any ideas for this issue?
Best regards,
Wolfgang
On Thu, 2006-09-28 at 13:23 +0200, wqual wrote:
Hi list,
dbf-table first.
Use the 'cnames' option in v.in.ogr to manually specify column names.
Brad Douglas <rez touchofmadness com> KB8UYR
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
