[GRASS-user] grass instalation on fc4
Hello :slight_smile:
I am trying to install grass on fc4… but i can t find any of the packages on synaptic… Isn t there ant repostories i should add ??
plesase help me :frowning:
http://www.public.asu.edu/~iullah/fc4.html
Hi :slight_smile:
I get this problem :
[root@ana gdal-1.3.1]# ./configure --without-grass --with-hdf4=/usr/local/hdf4.2r1 --with-libtiff=internal --with-geotiff=internal --with-python --without-ogdi --without-libgrass --enable-shared
checking build system type… i686-pc-linux-gnu
checking host system type… i686-pc-linux-gnu
checking target system type… i686-pc-linux-gnu
checking for gcc… gcc
checking for C compiler default output file name… a.out
checking whether the C compiler works… yes
checking whether we are cross compiling… no
checking for suffix of executables…
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether gcc accepts -g… yes
checking for gcc option to accept ANSI C… none needed
checking for g++… g++
checking whether we are using the GNU C++ compiler… yes
checking whether g++ accepts -g… yes
checking for a sed that does not truncate output… /bin/sed
checking for egrep… grep -E
checking for ld used by gcc… /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld… yes
checking for /usr/bin/ld option to reload object files… -r
checking for BSD-compatible nm… /usr/bin/nm -B
checking whether ln -s works… yes
checking how to recognise dependent libraries… pass_all
checking how to run the C preprocessor… gcc -E
checking for ANSI C header files… yes
checking for sys/types.h… yes
checking for sys/stat.h… yes
checking for stdlib.h… yes
checking for string.h… yes
checking for memory.h… yes
checking for strings.h… yes
checking for inttypes.h… yes
checking for stdint.h… yes
checking for unistd.h… yes
checking dlfcn.h usability… yes
checking dlfcn.h presence… yes
checking for dlfcn.h… yes
checking how to run the C++ preprocessor… g++ -E
checking for g77… no
checking for f77… no
checking for xlf… no
checking for frt… no
checking for pgf77… no
checking for fort77… no
checking for fl32… no
checking for af77… no
checking for f90… no
checking for xlf90… no
checking for pgf90… no
checking for epcf90… no
checking for f95… f95
checking whether we are using the GNU Fortran 77 compiler… yes
checking whether f95 accepts -g… yes
checking the maximum length of command line arguments… 32768
checking command to parse /usr/bin/nm -B output from gcc object… ok
checking for objdir… .libs
checking for ar… ar
checking for ranlib… ranlib
checking for strip… strip
checking if gcc static flag works… yes
checking if gcc supports -fno-rtti -fno-exceptions… no
checking for gcc option to produce PIC… -fPIC
checking if gcc PIC flag -fPIC works… yes
checking if gcc supports -c -o file.o… yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries… yes
checking whether -lc should be explicitly linked in… no
checking dynamic linker characteristics… GNU/Linux ld.so
checking how to hardcode library paths into programs… immediate
checking whether stripping libraries is possible… yes
checking if libtool supports shared libraries… yes
checking whether to build shared libraries… yes
checking whether to build static libraries… yes
configure: creating libtool
appending configuration tag “CXX” to libtool
checking for ld used by g++… /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries… yes
checking for g++ option to produce PIC… -fPIC
checking if g++ PIC flag -fPIC works… yes
checking if g++ supports -c -o file.o… yes
appending configuration tag “F77” to libtool
checking for f95 option to produce PIC… -fPIC
checking if f95 PIC flag -fPIC works… yes
checking if f95 supports -c -o file.o… yes
checking whether the f95 linker (/usr/bin/ld) supports shared libraries… yes
checking for dlopen in -ldl… yes
checking for nanosleep in -lrt… yes
checking for main in -lm… yes
checking for ANSI C header files… (cached) yes
checking assert.h usability… yes
checking assert.h presence… yes
checking for assert.h… yes
checking fcntl.h usability… yes
checking fcntl.h presence… yes
checking for fcntl.h… yes
checking for unistd.h… (cached) yes
checking dbmalloc.h usability… no
checking dbmalloc.h presence… no
checking for dbmalloc.h… no
checking for dlfcn.h… (cached) yes
checking for stdint.h… (cached) yes
checking limits.h usability… yes
checking limits.h presence… yes
checking for limits.h… yes
checking locale.h usability… yes
checking locale.h presence… yes
checking for locale.h… yes
checking values.h usability… yes
checking values.h presence… yes
checking for values.h… yes
checking float.h usability… yes
checking float.h presence… yes
checking for float.h… yes
checking whether byte ordering is bigendian… no
checking for 64bit integer type… long long
checking for 64bit file io… yes
checking for int… yes
checking size of int… 4
checking for long… yes
checking size of long… 4
checking for int8… no
checking for int16… no
checking for int32… no
checking native cpu bit order… lsb2msb
checking for vprintf… yes
checking for doprnt… no
checking for vsnprintf… yes
checking for snprintf… yes
checking for atoll… yes
checking for gmtime_r… yes
checking for localtime_r… yes
checking for setlocale… yes
checking for local include/lib path… none
configure: checking whether we should include thread/mutex support…
thread safe support disabled.
checking for deflateInit
in -lz… yes
using pre-installed libz
checking for pg_config… no
checking for PostgreSQL… GRASS support disabled.
checking for ffopen in -lcfitsio… no
libcfitsio not found - FITS support disabled
checking for Mopen in -lcsf… no
checking csf.h usability… no
checking csf.h presence… no
checking for csf.h… no
using internal csf code.
checking for nc_open in -lnetcdf… no
libnetcdf not found - netCDF support disabled
checking for png_set_IHDR in -lpng… yes
checking png.h usability… yes
checking png.h presence… yes
checking for png.h… yes
using pre-installed libpng.
using internal TIFF code.
using internal GeoTIFF code.
checking for jpeg_read_scanlines in -ljpeg… yes
checking jpeglib.h usability… yes
checking jpeglib.h presence… yes
checking for jpeglib.h… yes
checking for width_in_blocks in jpeglib.h… yes
using pre-installed libjpeg.
checking for DGifOpenFileName in -lgif… yes
using pre-installed libgif.
ogdi support disabled.
checking for FMEObjects… no
checking for SDreaddata in -lmfhdf… no
checking for SDreaddata in -lhdf4… no
configure: error: HDF4 support requested with arg /usr/local/hdf4.2r1, but neither hdf4 nor mfhdf lib found
But :
]# rpm -Uhv hdf-4.2r1-6.fc4.i386.rpm
Preparing… ########################################### [100%]
package hdf-4.2r1-6.fc4 is already installed
:frowning:
2006/6/16, M S <mseibel@gmail.com>:
hi. i’m on FC4 too and have compiled from source. if there’s anything i can help with please let me know.
grassuser mailing list
grassuser@grass.itc.it
Hello,
I think it is normal, your rpm only install this file :
/usr/bin/gif2hdf
/usr/bin/h4cc
/usr/bin/h4fc
/usr/bin/h4redeploy
/usr/bin/hdf24to8
/usr/bin/hdf2gif
/usr/bin/hdf2jpeg
/usr/bin/hdf8to24
/usr/bin/hdfcomp
/usr/bin/hdfed
/usr/bin/hdfimport
/usr/bin/hdfls
/usr/bin/hdfpack
/usr/bin/hdftopal
/usr/bin/hdftor8
/usr/bin/hdfunpac
/usr/bin/hdiff
/usr/bin/hdp
/usr/bin/hrepack
/usr/bin/jpeg2hdf
/usr/bin/paltohdf
/usr/bin/r8tohdf
/usr/bin/ristosds
/usr/bin/vmake
/usr/bin/vshow
/usr/share/doc/hdf-4.2r1
/usr/share/doc/hdf-4.2r1/COPYING
/usr/share/doc/hdf-4.2r1/HISTORY.txt
/usr/share/doc/hdf-4.2r1/MANIFEST
/usr/share/doc/hdf-4.2r1/README
/usr/share/doc/hdf-4.2r1/RELEASE.txt
/usr/share/doc/hdf-4.2r1/bugs_fixed.txt
/usr/share/doc/hdf-4.2r1/misc_docs.txt
/usr/share/man/man1/hdf.1.gz
/usr/share/man/man1/hdfunpac.1.gz
So try to change :
./configure --without-grass --with-hdf4=/usr/bin/ --with-libtiff=internal
--enable-shared
or
./configure --without-grass --with-hdf4 --with-libtiff=internal
--enable-shared
Y.
Le Vendredi 16 Juin 2006 19:32, Ana Soares a écrit :
Hi :slight_smile:
--enable-shared
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for a sed that does not truncate output... /bin/sed
checking for egrep... grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... f95
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether f95 accepts -g... yes
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc static flag works... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries...
yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries...
yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ supports -c -o file.o... yes
yes
appending configuration tag "F77" to libtool
checking for f95 option to produce PIC... -fPIC
checking if f95 PIC flag -fPIC works... yes
checking if f95 supports -c -o file.o... yes
checking whether the f95 linker (/usr/bin/ld) supports shared libraries...
yes
checking for dlopen in -ldl... yes
checking for nanosleep in -lrt... yes
checking for main in -lm... yes
checking for ANSI C header files... (cached) yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for unistd.h... (cached) yes
checking dbmalloc.h usability... no
checking dbmalloc.h presence... no
checking for dbmalloc.h... no
checking for dlfcn.h... (cached) yes
checking for stdint.h... (cached) yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking values.h usability... yes
checking values.h presence... yes
checking for values.h... yes
checking float.h usability... yes
checking float.h presence... yes
checking for float.h... yes
checking whether byte ordering is bigendian... no
checking for 64bit integer type... long long
checking for 64bit file io... yes
checking for int... yes
checking size of int... 4
checking for long... yes
checking size of long... 4
checking for int8... no
checking for int16... no
checking for int32... no
checking native cpu bit order... lsb2msb
checking for vprintf... yes
checking for _doprnt... no
checking for vsnprintf... yes
checking for snprintf... yes
checking for atoll... yes
checking for gmtime_r... yes
checking for localtime_r... yes
checking for setlocale... yes
checking for local include/lib path... none
configure: checking whether we should include thread/mutex support......
checking for deflateInit_ in -lz... yes
checking for pg_config... no
checking for PostgreSQL... GRASS support disabled.
checking for ffopen in -lcfitsio... no
checking for Mopen in -lcsf... no
checking csf.h usability... no
checking csf.h presence... no
checking for csf.h... no
checking for nc_open in -lnetcdf... no
checking for png_set_IHDR in -lpng... yes
checking png.h usability... yes
checking png.h presence... yes
checking for png.h... yes
checking for jpeg_read_scanlines in -ljpeg... yes
checking jpeglib.h usability... yes
checking jpeglib.h presence... yes
checking for jpeglib.h... yes
checking for width_in_blocks in jpeglib.h... yes
checking for DGifOpenFileName in -lgif... yes
checking for FMEObjects... no
checking for SDreaddata in -lmfhdf... no
checking for SDreaddata in -lhdf4... no
But :
Preparing... ###########################################
[100%]
:frowning:
> hi. i'm on FC4 too and have compiled from source. if there's anything i
> I am trying to install grass on fc4... but i can t find any of the
> packages on synaptic.... Isn t there ant repostories i should add ??
> http://www.public.asu.edu/~iullah/fc4.html&lt;http://www.public.asu.edu/~i
>ullah/fc4.html>
Yves Jacolin
http://yjacolin.gloobe.org
http://softlibre.gloobe.org
you’re trying to compile GDAL or GRASS?
On 6/16/06, Ana Soares <tiobrothercamarada@gmail.com> wrote:
Hi :slight_smile:
checking for ar… ar
in -lz… yes
But :
:frowning:
Ana Soares wrote:
Hi :slight_smile:
--enable-shared
GDAL problems should really go to the GDAL list.
But :
[100%]
You need the corresponding -devel package, which is probably:
http://download.fedora.redhat.com/pub/fedora/linux/extras/4/i386/hdf-devel-4.2r1-6.fc4.i386.rpm
