[GRASS-user] grass live CD for education
I am giving GRASS (and open source GIS) workshops every now and then. The next one is in a few weeks. The problem is, I have only windows machines available, and I have had bad experiences with badly installed CYGWIN and GRASS versions in the past. (I have to leave it to the sysadmins).
I have proposed to use linux liveCD's but I am not allowed to use them due to security reasons (access to the HD and network).
Theoretically it does not seem to be too difficult to disable those functions on a liveCD. Although I am an experienced linux user, I have no experience with liveCD's. So before I spend a lot of time trying, I would like the opinion of the mailing list.
Specifically:
- anyone with experience making linux live CD's including grass?
- if so, which distribution to start with (knoppix seems a logical choice and has a good customisation manual)
- any hidden snakes under the grass that anyone knows of?
Wouter
There's
http://wiki.debian.org/DebianLive/
which you can combine with the DebianGIS repository:
http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl
Moritz
Certainly, you could create a LiveCD which lacks support for hard
disks and network adapters (although you are going to be rather
limited in the amount of data you can handle if your filesystem has to
fit into RAM).
However, the issue may not be whether the LiveCD is actually safe, but
whether the admins *know* that it is safe, and are willing to make the
necessary changes to accomodate this (I would assume that the machines
are configured not to boot from removable media).
you can try the following Live-CD
http://livecd.ominiverdi.org
Gustavo
wouter.buytaert@scarlet.be escribió:
Specifically:
Wouter
grassuser mailing list
grassuser@grass.itc.it
Hi Wouter,
At http://livecd.ominiverdi.org/ you can found more info about our GIS Livecd Project.
The latest stable is the "Desktop Edition 2007.0" with:
GRASS 6.2.1
QGIS 0.8
PostgreSQL 8.1.5
POSTGIS 1.14
GDAL 1.3.2
ecc...
There are also some sample data inside (as file and inside Postgis).
Currently we are working on the "Server Edition 2007.0" and on the "Desktop Edition 2007.1",
but we can't say when will be finished.
If need more info ( like a specific customization), let me know.
Bye
Luca
Ominiverdi Livecd Team
Il giorno 18/mag/07, alle ore 18:05, wouter.buytaert@scarlet.be ha scritto:
Specifically:
Wouter
Dear Wouter,
About LiveCD with GRASS, I suggest to prove the POSEIDON linux distribution. This is Knoppix modified which contain a lot of software for GIS as GRASS, QGIS, SPRING, and other more.
To get this distribution you must go to
http://poseidon.furg.br/index.php?option=com_frontpage&Itemid=1
I used this distrubution to show in my institution that linux ang GRASS are an alternative to other Arc-nnn software.
Sincerely yours
Leonidas
2007/5/18, wouter.buytaert@scarlet.be <wouter.buytaert@scarlet.be >:
I have proposed to use linux liveCD’s but I am not allowed to use them due
experience with liveCD’s. So before I spend a lot of time trying, I would
Specifically:
  • anyone with experience making linux live CD’s including grass?
  • if so, which distribution to start with (knoppix seems a logical choice
  • any hidden snakes under the grass that anyone knows of?
Wouter
Leonidas Carrasco-Letelier
INIA-La Estanzuela Tel: +598 574 8000
Colonia Fax.:+598 574 8012
URUGUAY www.inia.org.uy
This is an extraordinarily timely request. Linux is a great OS, and a live
CD can make it available to Windows users without installing it. However, if
people are not interested in committing to installing Linux on their own
machine, then training on software that runs only on this OS doesn't help
much. I've taught with GRASS under Cygwin. It was possible, but a real pain
in a lab setting. But now you have a very nice alternative.
I'm copying below a notice that went out to the GRASS developers list within
the past hour. If you want, you CAN get an easy to install Windows version
of GRASS without Cygwin. One of my grad students tried out a version of a
couple weeks ago and reported it to be very nice and fast...and easy to
install. It is simply a zip file. The only thing that you might need to
install extra is a program called Mysys. I think that this is covered in the
readme.
I'm copying the binary maintainer, Moritz Lennert, in case he has something
else to add.
Michael
------ Forwarded Message
From: Moritz Lennert <mlennert@club.worldonline.be>
Date: Fri, 18 May 2007 16:18:48 +0200
To: <wingrass@grass.itc.it>, Grass Developers List <grass-dev@grass.itc.it>,
GRASS users list <grassuser@grass.itc.it>
Subject: [GRASS-user] native winGRASS pre-alpha testers needed
Hello,
I have updated the GRASS native win package at
http://moritz.homelinux.org/grass/wingrass/
(see instructions in the README file)
We definitely need testers if we want to speed up development on this. I
don't have much time to spend on testing at the moment. Even though you
can use a variety of modules in winGRASS, we are still far from a really
usable port. Only testing (and fixing :wink: ) will get us there.
Moritz
On 5/18/07 9:05 AM, "wouter.buytaert@scarlet.be"
<wouter.buytaert@scarlet.be> wrote:
Specifically:
Wouter
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Dear Wouter..
do you know this:
http://livecd.ominiverdi.org/index.php?page=LiveCD&toc=livecd
hope this help...
cheers
Il giorno ven, 18/05/2007 alle 17.05 +0100, wouter.buytaert@scarlet.be
ha scritto:
Specifically:
Wouter
Ti prego di cercare di non inviarmi files .doc, .xls, .ppt, .dwg.
Preferisco formati liberi.
Please try to avoid to send me .doc, .xls, .ppt, .dwg files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini@unipg.it
        ivan.marchesini@gmail.com
tel: +39(0)755853760
fax (university): +39(0)755853756
fax (home): +39(0)5782830887
jabber: geoivan73@jabber.org
Great to hear such positive feedback !
I do wish to warn you, however, that this windows version is still in an early phase and many things do not work as they do in the *nix version. Also note that there are no xmonitors in this version, so the only way to display things is via the tcltk gis manager.
The best thing would be for you to try and see if you can do everything you want to do for your workshop, and if it does, then hope that during the workshop noone wants to try anything else :wink:
In any case, if you try it, please give us a feedback.
and easy to
readme.
You also have to install TclTk. We hope to include this in a future version, but currently this is a dependency.
Msys is necessary if you want to run some of the script modules which are full of *nix "shellisms".
Moritz
You can do *almost* anything from the GUI that you can do from the command
line. Apparently, nviz is the biggest problem--but I don't know why it
shouldn't run.
Michael
phone: 480-965-6213
fax: 480-965-7671
Maybe Cygwin is a bit improved now? Did you try 6.2.1? We have made
the install a bit easier now with good automatic dependency hinting.
It still takes a little time to install, but should be much smoother- it
might be worth the trouble of re-testing on 1 machine.
http://grass.ibiblio.org/grass62/binary/mswindows/
If all Cygwin, Linux LiveCD, experimental 6.3 Native versions don't
work, there is some access to the GRASS toolbox in QGIS 0.8 for Win?
Hamish
There's
Using PCLOS as your distro, it is easy to set up a custom install, then run mklivecd to turn your install into a LiveCD. So if your system does not enable network access (you'll still need your loopback device) nor enables HDD access, your LiveCD won't either.
This article describes how to do this with QGIS, but installing GRASS instead/as well will work just as well.
http://qgis.org/content/view/63/65/
PCLOS is focussed very much on ease of use, & I have found non-Linux users to be more comfortable with it than Knoppix LiveCD's. Very much a matter of opinion though :slight_smile:
HTH,
  Brent Wood
